Release 3.0.0.194 is available for software and all controllers, see below for download instructions.
Changes from 3.0.0.187:
* New JSON commands added, see latest JSON docs here: http://forums.homeseer.com/showthread.php?t=160062
* Added device option in device properties to not update last change time if device does not actually change status.
* Some formatting fixes on device management page.
* Added support for new Z-Tool+ mobile Z-Wave installation tool.
Release 3.0.0.187 is available for software and all controllers.
Changes from 3.0.0.181:
* New icons with consistent look added, icons are now selectable as a set from setup/Custom page. 2 sets are available, the new Contemporary set and the previous "Classic" set. Contemporary is the default. You may need to clear your images cache in your browser to see the changes.
* Changed the min width of the Name column on the device management page to keep it from being too small, refresh your web page to insure you get the new style sheet.
* A fix was added for compacting the energy database.
* MyHS now loads pages faster.
* Added a setting in setup to disable checking for updates.
* Sorting on device management page now sorts properly if sorted values contain numbers.
* Fixed playing wave files from speaker clients on Linux.
* By default the address and device image columns are disabled, enable on the custom page in setup if needed.
* On HomeTroller SEL static IP now needs to be set using system settings from graphical UI.
* Fixed runevent JSON command.
Changes from 3.0.0.180:
* Removed excessive scripting log messages that were added in build 180
* Zee build now includes Z-Wave plugin 3.0.1.10
To update to the latest:
For HS3 software, just restart HS3, it will prompt you to update. The download is also available from the downloads page at homeseer.com.
For all controllers, go into Setup, click the Update button.
For manual install on a Linux system, TAR file gzipped:
Tar file download:
http://homeseer.com/updates3/hs3_linux_3_0_0_194.tar.gz
NOTE: For Linux, HS3 has only been tested with MONO 3.2.8, other versions of MONO probably will have issues and are not supported as of this version.
Tar file download:
