When I issue a hs command to my echo i get the response your hs3 system needs to be updated to use this feature of your echo. I'm running the latest hs3 beta.
Error after hs3 beta update
Originally posted by MStan View PostWhen I issue a hs command to my echo i get the response your hs3 system needs to be updated to use this feature of your echo. I'm running the latest hs3 beta.
Apologies to those of you who were using the previously released Echo Skill, we are working on an email to send out to you.
We decided to update the Skill and it was released yesterday. While some of you had the skill working ok, most users (including myself!) could not get it to work. The problem was that the skill contains all the phrases and words that Alexa must listen for (jnlcuding event names and trigger phrases). This is a problem since there is no way we can add all the words that match your device names/locations/events. The new skill released yesterday simply passes the raw phrase that was spoken to HS. HS then does all the phrase parsing based on the names of your devices. This is a magnitude better. It also gives us control of the phrasing so we can update as needed.
To get your voice commands working again, update to build 3.0.0.239 or later. If you do not want to load a Beta, hold off for a few days as we plan on releasing this build ASAP.
You will probably need to disable and re-enable the skill.
Details on the phrases are here:
http://homeseer.com/amazon-echo-integration.html
Another thread touched on this problem...there's a 239 update you should grab, then make sure for each device you have been controlling in your HS setup that you now tick the checkbox for Voice Control for that device...obligatory now, didn't seem to matter before.
That update and ticking the boxes have my physical Echo/Alexa back to controlling HS3 without getting the Alexa error saying I needed to update.
Originally posted by smcwilliams View PostAnother thread touched on this problem...there's a 239 update you should grab, then make sure for each device you have been controlling in your HS setup that you now tick the checkbox for Voice Control for that device...obligatory now, didn't seem to matter before.
Check to make sure you running HS 3.0.0.239, check the about page. If you are, also disable and re-enable the HS skill. If still not working, post the exact message you are getting back.
Also, it might be caching your version number, try restarting HS, as that will cause the system to re-connect to the service and update your version #.
Originally posted by MStan View PostDid all of the above same issue. What do I have to update i'm running the S6 if that makes any difference.
1. Disable, then re-enable your HomeSeer skill.
2. Update your HS3 system to at least version 239, then restart HomeSeer.
3. Make sure any devices you wish to control are 'Voice Command' enabled.
This is done by going to the configuration tab of the device and enabling 'Voice Command'.Wade
"I know nothing... nothing!"
Originally posted by rjh View PostCheck to make sure you running HS 3.0.0.239, check the about page. If you are, also disable and re-enable the HS skill. If still not working, post the exact message you are getting back.
Yout hs3 system needs to be updated with version 3.0.0.239 or later to use this feature of your echo.
And it is.
