INSTALLATION / CONFIGURATION
System Requirements:
This plugin is for HS3 or HS3PRO.
It is designed to allow HomeSeer to configure, monitor and control the GPIO (General Purpose Input/Output) of a Raspberry Pi. It works with any version of Raspberry Pi.
Plugin Installation on your HS3 machine
Download and install from the updater ("Analog & Digital Input/Output Device" section) or download package from the Beta Testing thread and follow instructions to install.
If your HS3 machine is not a Raspberry Pi you don't need to enable the plug-in (but you still have to install it)
Plugin Installation on a Raspberry Pi which is not your HS3 machine
If you want to monitor/control GPIO of a Raspberry Pi which is not your HS3 machine, you need to run it as a remote plugin.
WARNING: if your HS3 server run on Windows you MUST run mono version 4 or above on your Raspberry Pi. Here is a Guide to update Mono to version 4 or above on Raspbian.
Here is the installation steps from the command line (tested on Raspbian)
1. create a directory where you want to install, and enter it:
2. download the plug-in remote install archive and unzip it. (This archive contains the plug-in files and the Homeseer libraries needed to run a plug-in remotely)
3.make the "run.sh" script executable
4. edit the run script
5. replace
- <raspberryio_absolute_path> with the absolute path of the directory where you installed the plugin
- <ip_of_your_hs_machine> with the actual IP of your HS3 machine
- <instance_name> with a name for this instance of the plugin (no space or special characters).
Type Ctrl+X, then Y to save the file.
here is for example what my run.sh looks like:
6. last step is to actually run the script
If everything is ok, you should see the init sequence like above, and in the 'PLUG-INS > Manage' page you should see your instance in the Remote Plug-Ins section like in the screenshot below:
7. (optional) If you want the plugin to be started automatically when your Raspberry Pi boot, edit the file /etc/rc.local
and add the following line (adapting the path of your run.sh accordingly to your system) at the end just above the "exit 0" command
To use the plugin with multiple Raspberry Pi, simply repeat step 1 to 7 on each RPi, making sure to use a different instance name on each one.
Plugin Configuration
Go to the config page 'PLUG-INS > RaspberryIO > Config - InstanceName', and configure the pins you want to use as Input/Output
mkdir RaspberryIO cd RaspberryIO
wget -O RaspberryIO_remote_install_3-0-0-22.zip 'https://www.dropbox.com/scl/fi/h3m0rdgm77uyfkimlr9y4/RaspberryIO_remote_install_3-0-0-22.zip?rlkey=vnjc28a3hjwa7fau1j6qf3l7l' unzip RaspberryIO_remote_install_3-0-0-22.zip
chmod +x run.sh
pico ./run.sh
#!/bin/sh cd /home/homeseer/RaspberryIO mono HSPI_RaspberryIO.exe server=192.168.0.2 instance=TestRemote autoreconnect=30
spud@rpi ~/RaspberryIO $ sudo ./run.sh Plugin: RaspberryIO Instance: TestRemote starting... Connecting to server at 192.168.0.2... Connection attempt #1 Connected (HomeSeer API 3). Waiting to be initialized... Sep-13 14:29:41 INFO RaspberryIO version 3.0.0.21 Sep-13 14:29:41 INFO Raspberry Pi running on Bcm2709 processor Sep-13 14:29:41 INFO Firmware rev10620993, board model B2 (Raspberry Pi 2 Model B)
sudo pico /etc/rc.local
sudo /home/homeseer/RaspberryIO/run.sh & exit 0
