Originally posted by mnsandler
View Post
yes - same behavior in .16
I don't have a fan for heating. The RC-80 is setup for singlr stage heat only.
The 80B is setup for heat/cool - the cool side (AC) has the fan. All is programmed corectly via HAI's instructions. Both stat's are wireed as per figure 5 using RWC single stage heat. Currently the AC is not wired up. The 80 is setup with option 02 set to 12 and the 80B set to 4 (Page 11 of manual or 13 of attached pdf) when either stat calls for heat, the plug-in states system "heating" and fan "running" for that stat.
