I just noticed a very strange issue with my Omnistat2s (firmware 1.02c), connected to HAI T-stat plug-in (vers 1.0.16.0) under HS 2.3.0.19.
If I change the heat point using the pull-down temperature list in the HAI RC Thermostat Status page (i.e., under Plug-Ins -> HAI RC Thermostat) I am not able to set the heat point to 64F. The HS log indicates that the heat point has been changed to 64F, but instead the actual heat point on the stat is changing to 63F.
However, if I instead control the heat set point using the up/down controls on the heat point device from the HS status page, I have no problem stepping through all temperatures, including 64F.
Would someone with an Omnistat2 please give this a try and let me know if I'm going crazy?
Don
Don
