Originally posted by RBergquist
View Post
HS3 Vista Alarm plugin v3.0.0.10 Release
Mark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View PostIn my code i have it set to 'not' trigger when changing the partition value. I think i was trying to mimic logic from hs2 but clearly its different. I'll fix this for the next version.Mark
HS3 Pro 4.2.19.5
3.0.0.10 Partition change device triggering is working for me.
I like the new HS3 functionality of triggering on the Partition change.
Thanks for the update.
Originally posted by billbingaman View PostI have it installed, but have some questions. What is a partition?
I set up my zones, but do not know how to test it. The virtual keypad work great.
what vista model do you have?
you need to create 1 partition in plugin and assign the address used in your panel? for vista 15se or vista 20se, its probably address 31, for most other panels its probably addr 16Mark
HS3 Pro 4.2.19.5
I had bought this plug in HS2 and upgraded to hs3 and upgraded the plugin too, but please help in setup.
i have vista 20se
when i configured plugin as vista 10, w.ith partition adress 16,
it shows last panel message accurately, i created my 8 zones, but they dont show any status
when i configure plugin to vista 20, with partition adress 16 or 31, even last panel message does notupdate.
zones dont work at all
please help
with a 20se, select vista 20se and set the partition 1 address to 31 (its the only option for a 20se). you can't use the vista 20 selection.
also make sure to enter the user code on the main config page and the partition page. it needs to be in both placesMark
HS3 Pro 4.2.19.5
Right. Pick the 20 option and use address 31Mark
HS3 Pro 4.2.19.5
no luck
here is what it shows
On
Vista Alarm Monitor Status Vista 1 Vista Alarm Control Today
9:00:44 PM
Unknown
Vista Alarm System Status Vista 2 Vista Alarm System
Unknown
Vista Alarm Last Panel Message Vista 3 Vista Alarm Status Today
8:53:11 PM
Off
Vista Alarm System Low Battery Vista 4 Vista Alarm Status
Off
Vista Alarm AC Power Loss Vista 5 Vista Alarm Status
Off
Vista Alarm Telco Failure Vista 6 Vista Alarm Status
Unknown
Vista Alarm Vista Alarm Partition 1 Status Vista P1 Vista Alarm Partition
Off
Vista Alarm Vista Alarm Partition 1 Chime Vista P1C Vista Alarm Chime
http://board.homeseer.com/showthread.php?t=136097
if this doesn't work, then there issue with the connection of the ad2usb or its internal configurationMark
HS3 Pro 4.2.19.5
Originally posted by lazy_bums View PostThanks, that did it
forgot to set 31 via putty.
that did itMark
HS3 Pro 4.2.19.5
sorry to bother again
security system zones workin
but suddenly after that my zwave giving me trouble with errors like this
3/18/2014 2:02:24 AM ~!~Z-Wave Error~!~main controller: The interface appears to have been disconnected or is having a communication issue.
3/18/2014 2:07:56 AM ~!~Z-Wave Error~!~main controller: The interface appears to have been disconnected or is having a communication issue.
any known conflicts or settings to be adjusted??
no known conflicts
is your zwave interface on a serial usb port as well?
I'm wondering if the serial port class in .net 4.0 is unstable.
we were all using .net 2.0 with hs2 and everything was fine. but now with hs3 and .net 4.0 everyone's serial ports are going haywire.Mark
HS3 Pro 4.2.19.5
