I'm trying to convert my HS2 script that writes the device value to a SQL Server, to HS3. In HS2 this script was working well, but I keep getting an error I cannot get rid off.
The script is as follows:
I keep getting the following error in the log:
It looks to be related to the "SQLComm.ExecuteNonQuery()" command. Who does understand what is happening here?
'VB.Net script to write Homeseer 3 values to SQL Server Express 'Add this line to Homeseer\Config\Settings.ini ' ScriptingReferences=System.Data;System.Data.Dll ' Add this line to Homeseer\Scipts\Startup.ini ' hs.RegisterStatusChangeCB("L2DB.vb","Main") Imports System.Data.SqlClient Sub Main(ByVal Parms As Object) Dim device_name, device_id, dv, device_location, device_location2, deviceObj, device_type Dim hc, dc, dev_address, dn As String Dim device_value As Double Dim devRef As Integer Dim sdate, stime As String Dim cn As New SqlConnection("Server=192.168.2.25,1433;Database=Home;User ID=xx;Password=xxxxxx;Trusted_Connection=False;") hs.WriteLog("L2DB", "Script running") 'hdc = Parms(0) 'address of device dev_address = Parms(1) 'address of device device_value = Parms(2) 'new value of device devRef = Parms(4) 'Device reference of the device 'Device_id = hs.GetDeviceRef(hdc) deviceObj = hs.GetDeviceByRef(devRef) device_name = deviceObj.name(hs) device_location = deviceObj.location(hs) device_location2 = deviceObj.location2(hs) device_type = deviceObj.Device_Type_String(hs) 'device_status = hs.DeviceStatus(devRef) sdate = format(Now, "dd-MM-yyyy") stime = format(Now, "HH:mm:ss") cn.Open() hs.WriteLog("L2DB", "Connection is open") Dim SQLComm As New SqlCommand("UPDATE devices SET date ='" & sdate & "',time='" & stime & "',type='" & device_type & "',name='" & device_name & "',value='" & device_value & "',location='" & device_location & "',location2='" & device_location2 & "' WHERE code='" & dev_address & "' " & _ "IF @@ROWCOUNT=0 " & _ "INSERT INTO devices(date,time,code,type,status,name,value,location,location2) VALUES('" & sdate & "','" & stime & "','" & dev_address & "','" & device_type & "','" & device_name & "','" & device_value & "','" & device_location & "','" & device_location2 & "')", cn) SQLComm.ExecuteNonQuery() hs.WriteLog("L2DB", "Logged to Database: Address: " & dev_address & ", Device Name: " & device_name & ", New Value: " & device_value) cn.Close() hs.WriteLog("L2DB", "Connection is closed") End Sub
