I can see how to do the reverse, but is there a way to find a device name based on the Device Reference ID (or #).
re Scripting .. how to find Device name from Ref #
I don't think there is a scripting function that will do it. What is the circumstance where you need the capability?
Jon00 has a 'Device List Viewer' that makes it easy to find the device name if you know the Ref ID. Does that do what you want?Mike____________________________________________________________ __________________
Code:Sub Main(p as string) Dim dvRef Dim dv dvRef = hs.GetDeviceRefByName("Kitchen Desk Lights") if dvRef > 0 then dv = hs.GetDeviceByRef(dvRef) hs.WriteLog("Info","The name for the device is " & dv.name(hs)) hs.WriteLog("Info","The location for the device is " & dv.location(hs)) hs.WriteLog("Info","The location2 for the device is " & dv.location2(hs)) else hs.WriteLog("Error","Could not find the reference for the device specified.") end if End Sub
Code:Jan-20 7:23:27 PM Info The location2 for the device is Lighting Jan-20 7:23:27 PM Info The location for the device is Kitchen Jan-20 7:23:27 PM Info The name for the device is Desk Lights
Originally posted by Steve Q View PostGo to HS3 settings/custom and turn on the column for “device reference”. Then sort the web page by “ref”.
Sent from my iPad using TapatalkHS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
Uncle Mike.
This is a tremendous stride forward, from the "geekie" (not a users) perspective of the device list. I have to congratulate the creator of this tool.
However, I am looking for a way in a script, knowing the "Ref ID", find out "Name" that the user has given the device. Users like to work with words, computers with numbers .. Once I have the Name, then it will combined with other device info and then an email sent to a designated address. This must work in an unattended enviromnement.
Again, thanks for this info .. now I need to find a way to expand it so that it can be the solution I am looking for ...
Thanks for your help ...
Mr Happy
If this works then great ... why would anyone hide such tools that help others .. I just do not understand the development/tech staff at HS .. they were very user oriented when I first use HS1 .. but now it is geek city.
One stride forward .. 3 back .. too bad .. these are usual signs of impending demise.
I have been in IT for over 50 years and seen this happen toooooo many times.
Get off the soap box Don .. and Thanks .. .
Don
Originally posted by rprade View PostSadly, RefID is not a sortable column. That is one of many reasons Jon00's Device List Viewer is useful.HomeSeer Version: HS3 Pro Edition 3.0.0.368, Operating System: Microsoft Windows 10 - Home, Number of Devices: 373, Number of Events: 666, Enabled Plug-Ins
