For some reason everything has stopped working for me. I've made no changes, but I can't even simply turn lights on/off from the device list. I can't get at OMNIPRO log. Almost seems like the plugin is no longer talking to the OMNI panel, but it is since I can see the alarm zones change in the plugin. Help! I've done a soft and hard restart of my home troller zee S2.
I did notice that I'm running 3.0.2.8 which I did not install for fear of jumping to the latest release. Does Homeseer now automatically install the updates? UGH.
Thanks.
Here is the log from the reboot:
ay-08 7:51:28 PM
OMNI
May-08 7:51:28 PM
OMNI
Plugin startup is complete.
May-08 7:51:28 PM
OMNI
May-08 7:51:28 PM
OMNI
Synchronization complete.
May-08 7:48:36 PM
OMNI
Synchronizing OMNI devices with HomeSeer...
May-08 7:48:35 PM
OMNI
Requesting initial system troubles
May-08 7:48:29 PM
OMNI
Requesting Output status...
May-08 7:48:27 PM
OMNI
Requesting Area status...
May-08 7:48:27 PM
OMNI
All configuration and properties retrieved.
May-08 7:48:26 PM
OMNI
-->Reading properties...
May-08 7:47:37 PM
OMNI
-->Reading configuration...
May-08 7:47:29 PM
Startup
Start up complete.
May-08 7:47:29 PM
Info
System connected to MyHS Service successfully with license ID 98505.
May-08 7:47:29 PM
Info
Latest BETA update available is:
May-08 7:47:29 PM
Info
Latest update available is: 3.0.0.435
May-08 7:47:29 PM
Info
System connected to MyHS Service, waiting for acknowledge...
May-08 7:47:29 PM
TTS
Speak ():Welcome to Home-Seer
May-08 7:47:29 PM
Startup
Scripting is OK and is now running Startup.vb
May-08 7:47:29 PM
Info
Checking for updates...
May-08 7:47:29 PM
Startup
HSSentry is disabled in Setup, sentry will not be started.
May-08 7:47:29 PM
Startup
Starting Event Scheduler...
May-08 7:47:28 PM
Starting Plug-In
Plugin MyQ started successfully in 1113 milliseconds
May-08 7:47:27 PM
MyQ
Initializing version 1.1.17344.312
May-08 7:47:27 PM
Starting Plug-In
Initializing plugin MyQ ...
May-08 7:47:27 PM
Starting Plug-In
Plugin OMNI started successfully in 2430 milliseconds
May-08 7:47:26 PM
Info
Plugin MyQ has connected. IP:127.0.0.1:35765
May-08 7:47:25 PM
Warning
Attempt by plugin to register a duplicate link of OMNI. Plugin: OMNI Instance:
May-08 7:47:25 PM
Starting Plug-In
Initializing plugin OMNI ...
May-08 7:47:25 PM
Info
Plugin OMNI has connected. IP:127.0.0.1:35761
May-08 7:47:24 PM
Startup
Running the startup script Startup.vb
May-08 7:47:24 PM
Startup
Starting Find service...
May-08 7:47:24 PM
Startup
Updater services starting...
May-08 7:47:24 PM
Web Server
Web Server authorized local login successful from: 10.0.0.57 User: admin
May-08 7:47:24 PM
Database
Opening (Mode=Read/Write) up HomeSeer Energy database /usr/local/HomeSeer/Data/Energy/Energy.hsd
May-08 7:47:24 PM
Speech
Listening for remote speaker connections on port 10401
May-08 7:47:24 PM
Startup
Initializing Speaker Client Interface
May-08 7:47:24 PM
Startup
Start automation engine...
May-08 7:47:24 PM
Web Server
Web Server started on port 80
May-08 7:47:24 PM
Web Server
Local IP address is: 10.0.0.19
May-08 7:47:24 PM
Startup
HStouch server started, waiting for clients to connect.
May-08 7:47:24 PM
HSTouch Server
Server started on port 10200
May-08 7:47:24 PM
Plug-In
Finished initializing plug-in OMNI
May-08 7:47:24 PM
Plug-In
Finished initializing plug-in MyQ
May-08 7:47:23 PM
Startup
Initializing Plug-Ins
May-08 7:47:23 PM
Plug-In
Found plug-in: Z-Wave, version: 3.0.1.190
May-08 7:47:04 PM
Plug-In
Found plug-in: Honeywell WiFi Thermostat, version: 1.2.1.0
May-08 7:47:03 PM
Plug-In
Found plug-in: OMNI, version: 3.0.2.8
May-08 7:47:01 PM
Plug-In
Found plug-in: MyQ, version: 1.1.17344.312
May-08 7:47:00 PM
Database
Opening (Mode=Read/Write) up HomeSeer LOG database /tmp/HomeSeerLog.hsd
May-08 7:46:59 PM
Startup
Checking for available plug-ins
May-08 7:46:59 PM
Info
Remote plug-in API interface started on port 10400
May-08 7:46:59 PM
Startup
This version of HomeSeer is registered as a HS3ZEES2 version.
May-08 7:46:59 PM
Startup
Creating Speaker Client Interface Object...
May-08 7:46:59 PM
Startup
HomeSeer version is: 3.0.0.435
May-08 7:46:59 PM
Load Config
Loading TIMERS...
May-08 7:46:59 PM
Load Config
Loading COUNTERS...
May-08 7:46:59 PM
Load Config
11 total events loaded.
May-08 7:46:59 PM
Load Config
Loading Events...
May-08 7:46:59 PM
Load Config
Loading Event Groups...
May-08 7:46:59 PM
Load Config
117 total devices loaded.
May-08 7:46:59 PM
Database
Loading Devices...
May-08 7:46:58 PM
Database
Opening (Mode=Read Only) up HomeSeer database /usr/local/HomeSeer/Data/HomeSeerData.hsd
May-08 7:46:58 PM
Startup
Loading configuration file ...
May-08 7:46:58 PM
Startup
Database SAVE process started.
May-08 7:46:58 PM
Startup
Local voice recognition class started.
May-08 7:46:58 PM
Startup
Plug-In Interface class started.
May-08 7:46:58 PM
Startup
E-Mail RECEIVE class started.
May-08 7:46:58 PM
Startup
E-Mail SEND class started.
May-08 7:46:58 PM
Startup
Web server class started.
May-08 7:46:58 PM
Startup
Application interface class started.
May-08 7:46:58 PM
Startup
COM port classes started.
May-08 7:46:58 PM
Startup
Creating Class Objects...
May-08 7:46:58 PM
Startup
May-08 7:46:58 PM
Startup
May-08 7:46:58 PM
Startup
HomeSeer version 3.0.0.435 Edition: HS3 ZEE S2 Starting Now
May-08 7:46:58 PM
Startup
May-08 7:46:58 PM
Startup
May-08 7:46:56 PM
Startup
Settings Loaded.
78 log entries, displaying entries from 0
Home | Device Status | Device Management | Eve
Thanks.
ay-08 7:51:28 PM
OMNI
May-08 7:51:28 PM
OMNI
May-08 7:51:28 PM
OMNI
May-08 7:51:28 PM
OMNI
May-08 7:48:36 PM
OMNI
May-08 7:48:35 PM
OMNI
May-08 7:48:29 PM
OMNI
May-08 7:48:27 PM
OMNI
May-08 7:48:27 PM
OMNI
May-08 7:48:26 PM
OMNI
May-08 7:47:37 PM
OMNI
May-08 7:47:29 PM
Startup
Start up complete.
May-08 7:47:29 PM
Info
May-08 7:47:29 PM
Info
May-08 7:47:29 PM
Info
May-08 7:47:29 PM
Info
May-08 7:47:29 PM
TTS
May-08 7:47:29 PM
Startup
May-08 7:47:29 PM
Info
May-08 7:47:29 PM
Startup
May-08 7:47:29 PM
Startup
May-08 7:47:28 PM
Starting Plug-In
May-08 7:47:27 PM
MyQ
May-08 7:47:27 PM
Starting Plug-In
May-08 7:47:27 PM
Starting Plug-In
May-08 7:47:26 PM
Info
May-08 7:47:25 PM
Warning
May-08 7:47:25 PM
Starting Plug-In
May-08 7:47:25 PM
Info
May-08 7:47:24 PM
Startup
May-08 7:47:24 PM
Startup
May-08 7:47:24 PM
Startup
May-08 7:47:24 PM
Web Server
May-08 7:47:24 PM
Database
May-08 7:47:24 PM
Speech
May-08 7:47:24 PM
Startup
May-08 7:47:24 PM
Startup
May-08 7:47:24 PM
Web Server
May-08 7:47:24 PM
Web Server
May-08 7:47:24 PM
Startup
May-08 7:47:24 PM
HSTouch Server
May-08 7:47:24 PM
Plug-In
May-08 7:47:24 PM
Plug-In
May-08 7:47:23 PM
Startup
May-08 7:47:23 PM
Plug-In
May-08 7:47:04 PM
Plug-In
May-08 7:47:03 PM
Plug-In
May-08 7:47:01 PM
Plug-In
May-08 7:47:00 PM
Database
May-08 7:46:59 PM
Startup
May-08 7:46:59 PM
Info
May-08 7:46:59 PM
Startup
May-08 7:46:59 PM
Startup
May-08 7:46:59 PM
Startup
May-08 7:46:59 PM
Load Config
Loading TIMERS...
May-08 7:46:59 PM
Load Config
Loading COUNTERS...
May-08 7:46:59 PM
Load Config
May-08 7:46:59 PM
Load Config
Loading Events...
May-08 7:46:59 PM
Load Config
May-08 7:46:59 PM
Load Config
May-08 7:46:59 PM
Database
Loading Devices...
May-08 7:46:58 PM
Database
May-08 7:46:58 PM
Startup
May-08 7:46:58 PM
Startup
May-08 7:46:58 PM
Startup
May-08 7:46:58 PM
Startup
May-08 7:46:58 PM
Startup
May-08 7:46:58 PM
Startup
May-08 7:46:58 PM
Startup
May-08 7:46:58 PM
Startup
May-08 7:46:58 PM
Startup
May-08 7:46:58 PM
Startup
May-08 7:46:58 PM
Startup
May-08 7:46:58 PM
Startup
May-08 7:46:58 PM
Startup
May-08 7:46:58 PM
Startup
May-08 7:46:58 PM
Startup
May-08 7:46:56 PM
Startup
Settings Loaded.
