Hi All,
I have an a special event for my den where I have a master and a slave switch setup. But I also have my under counter lights and my server closet light set up in an event to come on when the Master transmits a fast on command.
It goes something like this.
If Den Master Light Transmits Fast On
then Beep Den Master Light
then Turn On Under Counter Lights to On
then Turn On Server Room Lights to On
My Issue is the it seems that I am having more that one device beep, I think the slave is beeping as well but the event is only setup for the master to beep. Could it be that the Master and Slave are Crossed link that is causing this issue? Is there any way to stop this second beep from occurring? I will set up a second event for the slave switch once I stop the beep occurring more than once.
Thanks Joe.
Thanks Joe.
