Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > Insteon Plug-in (Mark Sandler)
Insteon Plug-in (Mark Sandler) Discussions related to Mark Sandler's 3rd parth plug-in for controlling Insteon devices via Smarthome's PLM interfaces (the 2412 & 2413 series controllers)
Old October 7th, 2009, 12:26 PM
mnsandler's Avatar
Insteon Overlord
Question Feature Requests for the Mark Sandler Insteon PLM Plug-In
Please post replies with details of what you would like added to the plugin
thanks
Mark
HS3 Pro 3.0.0.368
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire3 | RFXCOM | NetCAM | MyQ | BLRadar | BLDenon | Jon00 Charting
Old October 7th, 2009, 06:59 PM
clicata clicata is offline
Seer Plus
My opinions:
- Post frequent updates. It's okay if there are small incremental steps in a positive direction.
- Keep the concept of Externally Registration of a device via the supplied VB script for cases of new device introduction and customization.
- Start simple: Allow proper Internal Registration (no need for the external script) of the newer firmware revisions of the existing devices that the plug-in supports. The last rev that HS put out on the Updater allows Internal Registration but doesn't do proper checking and sometimes there are errors.
- Add the most common missing devices to the supported devices list for Internal Registration.
That's a beginning.
Chuck
Old October 7th, 2009, 07:47 PM
TechHA's Avatar
TechHA TechHA is offline
First, thank you for taking on this task!
Now for some items:
- Add ability to set default on levels and ramp rates for each device registered.
- Add Motion Sensors within the Plug-in. Easier setup with naming, room selection.
Bryan
Software/Hardware: Win10 Pro, HS 3 Pro, HS Touch, Echo, Edgeport/4, Z-Net w/88 Devices, Insteon PLM w/19 Devices, Nest, GC-100-6, W800RF32A, WS-2080 Weather Station (KMADRACU10)
Plug-in/Scripts: Alexa API, BLBackup, BLGData, BLLED, BLLock, BLRF, BLTVGuide, Blue Iris, BLUPS, Current Cost 3P, DirectTV, FitbitSeer, Insteon, Nest, Pushover 3P, Random, Restart, Tasker, UltraGCIR3, UltraWeatherWU, Z-Wave
Old October 7th, 2009, 08:33 PM
mnsandler's Avatar
Insteon Overlord
Now for some items:
I understand the first item: on levels and ramp rates, great idea , and the motion sensor idea (i guess i need to buy one) but could you add some detail to the second, "Easier setup with naming, room selection". Are you referring to the initial setup of the device within the plugin, or something else? Maybe a screen shot would help
Old October 7th, 2009, 09:24 PM
TechHA's Avatar
Using the external script, I was never able to assign the motion sensors to different rooms. It would be great if they were setup within the plug-in similar to lighting devices.
Example: Insteon Device ID, Device Name, Device Location
Would be: xx.xx.xx, Motion Sensor, LivingRoom
This way the Motion Sensor in the LivingRoom could show up in the Status view with the other LivingRoom devices. Make sense?
Old October 7th, 2009, 10:23 PM
heatvent's Avatar
heatvent heatvent is offline
Basics:
1. I occassionally have a device that is not up to date but I get no warning from the plugin. Overall syncing of HS to the network is not the best and needs improvement. I would like to know when a HS device is out of sync and better yet have the plugin automatically fix it.
2. Insteon groups - There needs to be a feature to force sync the group and the lights. I have keypadlincs and if I turn them on / off with the group all is fine and I have them crosslincd on the network. However, if I use HS to turn on a light or to dim it to a set %, the other group members are not updated (i.e. the keypad button is not lit if the light is on). This seems like it could be a simple feature.
Old October 7th, 2009, 10:30 PM
heatvent's Avatar
Advanced:
1. Spidering of the network.
2. Much better link management. I would be a great feature to be able to use HS to manage links between devices.
Old October 8th, 2009, 09:41 PM
skozin's Avatar
skozin skozin is offline
Adding new devices such as the new 2476S relay switch. These are shown as "Unknown Device" in Homeseer.
Old October 13th, 2009, 04:07 PM
jono jono is offline
Some feature request ideas from my wish list (apologies in advance if some of this is aggressive):
1. I would like to be able to run the Hardware Reset and Reprogram Interface button on a scheduled basis, or from a HS event via a script.
2. When one replaces the PLM the Groups don't work. It would be really nice to have a button that rebuilds a group by deleting and then adding back all members of that group.
3. It would be nice to have on the summary page a warning about the number of Unknown Devices in the links of the all registered Insteon devices.
4. It would be nice to collect the Communication Reliability data over time and not have the figure reset every time HS restarts.
5. Device support inside the program for the EzSnsRf, EZ IO, thermostats, IRLinc, table top controllers and remotelinc.
6. A feature for creating links among devices rather than just detecting them (this may be beyond the scope of the plug in).
7. I would like to be able to register access points, and have a warning if any one is no longer working (I had one that died and presumably the PLM nor any other devices could not communicate with the access point but I had no way of knowing).
I am thrilled to see a rekindled effort towards improving the plug in. Many thanks.
Old October 15th, 2009, 09:30 AM
mnsandler's Avatar
Insteon Overlord
looking for feedback on the following thread
http://board.homeseer.com/showthread.php?t=138063
Old October 15th, 2009, 11:15 AM
heatvent's Avatar
As you can see, both jono and I seem to have the same issue with devices occassionally getting "out of sync" with HS. Probably the feature request should be a bug fix request instead to figure out why this is happening, is it an issue with the plugin? (i.e. treat the cold not the symptoms). It would still be nice to have the reporting of issues but I think there is probably something wrong on the front end.
Old October 15th, 2009, 12:39 PM
mnsandler's Avatar
Insteon Overlord
not sure i following complete; which item from jono's list are you referring to?
as for "out of sync", if i recall correctly, some devices like lamplincs and applicancelincs do not report out their status when turned on locally. so the device may be On but hs might still think it is Off. I use the plugin Polling feature to correct for this.
if this is not what you are referring to, please give me an example or more detail
Old October 15th, 2009, 02:24 PM
heatvent's Avatar
Maybe I misread what jono was saying, but I occassionally get a device that is not in sync with the database. The way I find this out is when I go to the particular devices management page in the plugin, there will be a warning message that the device contains links that don't match the HS database or something like that. I then reprogram the device to correct it. Not sure why this happens, I haven't added links to the devices so I think it may be HS that somehow gets out of sync and loses a link or two.
Old October 15th, 2009, 07:33 PM
When I swap out or replace devices (which I have had to do a few times) the plug in Swap feature doesn't necessarily get it all correctly. That is why I was looking for a warning when registered devices show links to Unknown Devices. It might be a catch-all notification for problems caused by an imperfect device swap, or the problem that heatvent is having.
Old October 23rd, 2009, 08:49 PM
mnsandler's Avatar
Insteon Overlord
Chuck,
can you give me a specific example of a device that the plugin recognizes but has a newer firmware that is causing problems. I need the problem caused by this newer firmware, ie what works or doesn't work.
Old October 24th, 2009, 11:19 AM
Spot Spot is offline
Seer Plus
I would like to see Comm reliability monitoring made more robust. I have been able to use the feature on the devices page to troubleshoot devices, but it would also like to:
1. Manual or script-based reset of the data vs losing it after each restart of the plugin
2. Scriptable variables to access the data for each device
3. Event triggers when comm becomes unreliable (can help Id a failed device)
Old October 24th, 2009, 06:06 PM
mnsandler's Avatar
Insteon Overlord
Originally Posted by Spot View Post
I would like to see Comm reliability monitoring made more robust. I have been able to use the feature on the deevices page to troubleshoot devices, but it would also like to:
i have just added the ability for the plugin to save/reload the comm data between restarts (thus no losing data). I will probably add a manual reset initially. the plugin tracks "total transactions" and "number of failures", i should be able to make these avail via script in a later version
Old October 25th, 2009, 06:50 PM
heatvent's Avatar
What is the plan for new releases. Will they go through the updater? Will there be beta releases? Is there a thread for "what's changed"? Etc.?
Old October 25th, 2009, 09:26 PM
mnsandler's Avatar
Insteon Overlord
I plan to post updates (via a zip file) here in the forum. (hst may post new stable versions in the updater) i will start a new thread and list the new features and fixes in the version.
i was thinking of starting a thread that everyone could subscribe to in order to get notified when i post the new version. what do you think?
Old October 26th, 2009, 05:05 PM
skozin's Avatar
That sounds great. Can't wait for the next update.
HTML code is On
Insteon thermostat - Feature requests claude Insteon Thermostat (3P) 11 April 11th, 2017 05:10 PM
Base HS Insteon Plugin versus Mark Sandler's amr42 Insteon Plug-in (Mark Sandler) 4 September 13th, 2016 10:57 AM
Insteon Thermostat for HS3 v3.0.5.3 - (requires Mark Sandler's HS3 Insteon plugin) nfrobertson Insteon Thermostat (3P) 10 July 24th, 2016 08:07 AM
Using Insteon App along with HS and Mark's plug-in wglong Insteon Plug-in (Mark Sandler) 5 February 13th, 2015 12:14 PM
Feature Requests for Insteon Plugin? wntdone Insteon Plug-in (Mark Sandler) 2 June 18th, 2010 10:57 AM
