Go Back   HomeSeer Message Board > Audio / Video and Infra-red (IR) Plug-ins > Audio / Video and Infra-red (IR) Discussion > BOSESoundTouch Plug-in (3P)
BOSESoundTouch Plug-in (3P) Forum for discussions related to the BOSESoundTouch Plug-In by ChrisH.
Old November 14th, 2017, 12:22 PM
ryanoly ryanoly is offline
Event THEN design
Say I have an event that does 4 different things to the player. For example turns player on, changes to preset 1, sets volume to 11 and set shuffle on.
If I understand the eventing system correctly it would not be a good idea to submit them all in the same then. Would I want to create a seperate "THEN" for each action?
Would I even consider pausing between each for a second or two. I know the change preset can take some time to actually go into affect for example.
Old November 14th, 2017, 12:43 PM
ChrisH ChrisH is offline
Do you have problems when they are all submitted to the player one after the other in a THEN? Think of the plugin as if it were the mobile app, just sending commands to the player. If you can get reliable behavior when sending everything all together then go for it. If perhaps the preset step takes a bit longer you might consider a wait step right afterwards.
HS3 design OS Gogs HS3 / HS3PRO Discussion 4 September 8th, 2016 09:07 PM
Some design help scotthpdx Audio / Video and Infra-red (IR) Discussion 5 June 9th, 2014 02:39 PM
New design Sheriff Designer 4 October 26th, 2013 07:05 PM
Simple event design question AZshooter HS2 / HSPRO 8 November 11th, 2006 05:16 PM
dxp pcb design irocknroll Electronic Circuits and Hardware Modifications 1 May 21st, 2006 06:30 AM
