Mark,
I just installed the AD2USB interface in my panel and configured my three partitions and associated zones. I updated the AD2USB to the current firmware in that process. The status of my zones and partitions isn't being updated, and the log shows mostly dumped or ignored messages (see attached).
I have the following alpha keypads defined in the panel:
Address Partition and hardware
0 P1, no hardware installed, default for Vista
1 P1, physical keypad (Garage)
2 P1, no hardware installed, required for TC
5 P1, physical keypad (Master Bedroom)
6 P2, physical keypad (Apartment)
7 P1, physical keypad (Guest Entry)
8 P3, physical keypad (Alarm Panel Closet)
18 P1, virtual KB for AD2USB
Looking at the messages and destination keypad address of the dumps, it appears that the panel is correctly reporting partition status (and sending it to the appropriate keypads). But all the input data seems to be ignored, so I suspect I've made some novice error here. I haven't been able to find an obvious match in the forum, so thanks in advance for your help!
Current Date/Time: 11/26/2017 4:30:06 PM
HomeSeer Version: HS3 Pro Edition 3.0.0.318
Operating System: Microsoft Windows 7 Professional - Work Station
System Uptime: 0 Days 4 Hours 42 Minutes 54 Seconds
IP Address: 172.16.200.234
Number of Devices: 588
Number of Events: 113
Available Threads: 400
Enabled Plug-Ins
3.0.0.68: HSTouch Server
2.17.0.10: MCSSPRINKLERSP
3.0.0.15: Vista Alarm
3.0.1.130: Z-Wave
Enabled Plug-Ins
3.0.1.130: Z-Wave
