Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > Insteon Plug-in (Mark Sandler)
Insteon Plug-in (Mark Sandler) Discussions related to Mark Sandler's 3rd parth plug-in for controlling Insteon devices via Smarthome's PLM interfaces (the 2412 & 2413 series controllers)
Old March 18th, 2018, 04:17 PM
claude claude is offline
HS3 'Do not log commands from this device' -vs- Insteon logging
Mark,
I have Insteon logging at 'normal'. I wanted to restrict some logging from MS devices, so I set the HS3 corresponding 'Heartbeat' and 'Occupancy sensor' sub-devices to 'Do not log commands from this device'. It seems that this last specification is respected for the 'Occupancy sensor' sub-device, but ignored for the 'Heartbeat' sub-device. Is this to be expected?
Old March 18th, 2018, 04:24 PM
mnsandler's Avatar
Insteon Overlord
Claude,
i'll have to check the code. i thought i checked that hs option for every single device before logging a message from that device.
Mark
HS3 Pro 3.0.0.368
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon 3.0.6.23 (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire | RFXCOM | NetCAM | MyQ | BLRadar | Jon00 Charting
Old March 18th, 2018, 04:34 PM
mnsandler's Avatar
Insteon Overlord
Can you post a sample of the Received message you are trying to avoid logging from each sub-device
Old March 18th, 2018, 04:42 PM
Heartbeat:
Mar-18 14:19:06 Insteon Device Motion sensor [2:Cuisine] MS2 (41.5C.CC) sent a heartbeat: Battery=Good, Temp=22.3333333333333, Light=74
Old March 18th, 2018, 05:19 PM
mnsandler's Avatar
Insteon Overlord
this is a plugin message not the actual Received message. The hs option only controls the original msg from the device which is raw the insteon message.
Old March 18th, 2018, 06:29 PM
Understood. I seem to remember we had a discussion on Insteon logging, but can't retrace it. Is there any 'easy' way to implement a logging toggle for Insteon plugin generated messages on a per device basis, similar to what HS is doing?
Old March 19th, 2018, 11:42 AM
mnsandler's Avatar
Insteon Overlord
i can't easily implement this across every device the plugin supports.
i will try this for the new MSii and let you test.
Old March 19th, 2018, 04:34 PM
Great place to start, thanks.
Old March 20th, 2018, 08:15 AM
mnsandler's Avatar
Insteon Overlord
I'm setting this up so it only affects Normal logging. that is, if you have the plugin set to debug or detailed logging, you will get those log msgs regardless of the hs setting for those devices.
Old March 20th, 2018, 02:36 PM
Totally makes sense.
Old March 21st, 2018, 09:16 AM
mnsandler's Avatar
Insteon Overlord
I just posted 3.0.6.31 in the beta section. It addresses the logging issue you mentioned. please test and report back when you can.
Old March 21st, 2018, 04:10 PM
Does the job so far. Thanks Mark.
HTML code is On
Logging commands from Jasco 45608 remote hankli Z-Troller™ 1 November 26th, 2011 11:50 PM
Insteon Status and logging Issues Pete Insteon Plug-in (Mark Sandler) 1 December 11th, 2009 08:26 AM
Device Commands for Insteon rcourtney002@ec.rr.com Insteon Plug-in (Mark Sandler) 3 January 13th, 2009 10:48 PM
Insteon actions .. logging file djbeam Insteon Plug-in (Mark Sandler) 0 May 21st, 2007 10:39 AM
Insteon local ON/OFF logging digidoc Insteon Plug-in (Mark Sandler) 6 January 23rd, 2006 04:11 PM
