Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > Insteon Plug-in (Mark Sandler)
Insteon Plug-in (Mark Sandler) Discussions related to Mark Sandler's 3rd parth plug-in for controlling Insteon devices via Smarthome's PLM interfaces (the 2412 & 2413 series controllers)
Old March 21st, 2018, 12:32 AM
claude claude is offline
plugin Behavior for 3-way switches
Mark,
I have 3-way switches that behave strangely. Switch 'A' has physical load control and 'B' is the slave. Both definitions have 'Sync linked responder devices' checked and identical settings.
If I ask the plugin to set device 'A' to DIM 40%:
  • the light comes On at 40% at the default ramp rate of 4 secs
  • the LED strip on switch 'A' shows 40%
  • the LED strip on switch 'B' shows 100%
If I ask the plugin to set device 'B' to DIM 40%:
  • the light comes On at 100% at an apparent ramp rate of .5 sec
  • the LED strip on switch 'A' shows 100%
  • the LED strip on switch 'B' shows 40%
So, different behavior depending on which switch is activated and LED strips are not synchronized.
On a detailed log, I see the plugin sending the first light '01 66', then '2E FF' to the linked responder device.
My objective: to get the LED strips synchronized at 40%. What do I need to do to achieve this?
Old March 21st, 2018, 09:25 AM
mnsandler's Avatar
Insteon Overlord
it sounds like the responder link in device A isn't set correctly
please make sure the links between the two devices use the same on level and ramp rates in the links. if all else fails, delete the links between the two devices and recreate them using the 'create crosslink' option
Mark
HS3 Pro 3.0.0.368
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon 3.0.6.23 (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire | RFXCOM | NetCAM | MyQ | BLRadar | Jon00 Charting
Old March 21st, 2018, 03:31 PM
I deleted the links between 'A' and 'B', then created a link between 'A' and 'B', specifying 'Cross link devices'. All the proper links were created.
Same behavior as before. Here are the definitions:
Old March 22nd, 2018, 08:27 AM
mnsandler's Avatar
Insteon Overlord
claude,
this is getting a little confusing...
i had this working (mostly), but made some changes to support syncing switches based on the link data from a kpl btn. for example, a ktn btn is linked to turn on a switch to 55%. the kpl btn goes on at 100% but the switch is supposed to follow the link data.
one problem is the hs UI doesn't really simulate the function of the physical switches. For example, I can't simulate fast-on with the UI which guarantees 100% regardless of any other settings.
here is what i'm trying to do now with the hs device controls:
1. On and Off buttons will act as a single press to the physical switch on/off so any linked devices will follow the link data. And the controller will also follow the default on value (as it does today)
2. slider will sync the responder to the same value as the controller; i don't think this is how physical switches work: for example if controller is set to 75% and the responder is set to 50%, and you dim the controller, the responder will dim relative to its starting position, not to the same level as the controller.
Old March 22nd, 2018, 02:30 PM
Mark,
I changed my event from using an HS command to using an Insteon command (see below) and everything works great now:
  • LED strips match
  • Light comes on at requested level regardless which of the two 3-ways I command
From a detailed log, I also see that the plugin manages the main device and its responder differently than with the previous approach I was using, acknowledging that ramping needs to use '2E': they both get '2E 6C'. In the previous approach, the plugin sent '2E FF' to the linked responder device.
Problem solved for me, but I'm just curious why the first approach sends 100% at .1 sec to the responder ?
Old March 22nd, 2018, 03:40 PM
mnsandler's Avatar
Insteon Overlord
Originally Posted by claude View Post
Mark,
  • LED strips match
to answer your question: a bug.
i think you are building events to do what the plugin is supposed to do using the 'sync linked responders' option.
i'm working on another version that should fix all this...fingers crossed
Old March 22nd, 2018, 07:13 PM
mnsandler's Avatar
Insteon Overlord
i posted 3.0.6.32. can you give it a try. i think it will keep the devices in sync as you wish without the events
Old March 23rd, 2018, 12:34 AM
Using an HS command 'set device to DIM 40%', both of the 3-way switches now have their LED strips in sync. Thanks.
Old March 23rd, 2018, 08:28 AM
mnsandler's Avatar
Insteon Overlord
thanks for reporting back.
and this is with all your events disabled?
please try other sync scenarios if you have time.
Old March 23rd, 2018, 12:39 PM
If I understand one of your previous posts on this, you're under the impression I'm sending the same command to both switches in a 3-way setup in order to synchronize the LED strips. That is not the case.
What I was trying to demonstrate was that, prior to v3.0.6.32, when sending a command to either (not both) of the 2 participants in a 3-way setup, the LED strips would not sync between the two devices. Sorry if I wasn't clear enough.
The bottom line is that you solved the issue. I see that you are now sending the same command to both the main device and its responder (if 'Sync linked responder devices' is checked).
I do have a new question about cross links, posted in a different thread.
Thanks again!
Old March 23rd, 2018, 12:45 PM
mnsandler's Avatar
Insteon Overlord
Thanks again!
thanks for the clarification. makes sense.
HTML code is On
Plugin breaks dimmer switches anstosa JowiHue Plug-In 7 February 2nd, 2018 01:00 PM
Interesting behavior with GE/Jasco wireless keypad control and GE/Jasco switches mikedr HomeSeer Z-Wave Plug-in 4 March 4th, 2015 10:17 PM
Z-Wave Switches Compared With UPB Switches - Advice Needed SouthFloridaMatt HomeSeer Z-Wave Plug-in 7 December 16th, 2010 11:52 AM
Programming switches through the plugin skozin Insteon Plug-in (Mark Sandler) 1 August 15th, 2010 09:18 AM
Is anyone else seeing this behavior? tmcgowan ISY Plug-in Beta (3P) 2 November 17th, 2009 04:41 PM
