Go Back   HomeSeer Message Board > Media Plug-ins > Media Discussion > PI-SonosController (3P)
PI-SonosController (3P) Discussion of Sonos Controller Plug-in
  #21
Old October 12th, 2017, 01:08 AM
dcorsus dcorsus is offline
OverSeer
Quote:
Originally Posted by The Profit View Post
Think deleting the plugin and reinstalling would maybe fix it? Maybe a file was corrupted when it installed? Maybe it’s HS3 .372? Should I update to HS3 .375? Your plugin is awesome, know you worked hard on this...just want to get it working.
It is something with the ini file so it is indeed either something with the HS version, .net version, position of the stars, solar eclips ...... but deleting the PI and re-installing won't make a difference. If there is something with the .ini file structure, just deleting that would be something to try but I think you already tried that. So I would start by going to .375 but I read some concerning things, which makes me wonder whether you should go back to (was it) 368.
I think you already know, but only delete or edit .ini files when HS3 is stopped (because it caches it)
Dirk
  #22
Old October 12th, 2017, 01:13 AM
The Profit's Avatar
The Profit The Profit is offline
Seer Deluxe
Linkgroup Configuration Table - Unable to add entry
Dirk
I have not tried deleting the Sonos.ini file....so the procedure for that would be to shut down HS3, delete Sonos.ini and then restart HS3?
Yes, I read your directions in your prior post and made sure to shut down HS3 prior to editing the Sonos.ini file.
Edit: Sorry meant to respond to all your questions. I would love to go back to .368 but just found out today that the backup I ran before I made the update to .372 didn’t work, for some reason my USB drive lost connection and didn’t give me an error that the backup failed so I’m SOL. The stars weren’t aligned in my favor....thinking I’m going to get BLBackup instead...my solution didn’t work.
  #23
Old October 12th, 2017, 01:44 AM
OverSeer
Correct. I thought you already tried that. If not, highly recommended to rule out anything fishy in the ini file that's I'm not seeing. There were times that a blank here or there would signal the end of a section or a file and bad things would happen but that is a LOOOONNNNNGGGG time ago.
Dirk
  #24
Old October 12th, 2017, 04:57 AM
The Profit's Avatar
Seer Deluxe
Dirk
Ok, I shut down HS3, deleted the Sonos.ini file and restarted HS3.....the manual linkgroup that you had me create was gone as expected, I tried to create a new one and had the same issue. So....is an update to HS3 .37? my best next step?
  #25
Old October 12th, 2017, 02:58 PM
The Profit's Avatar
Seer Deluxe
Dirk
Hey Dirk,
I’ve just updated to HS3 .376 and then after it finished loading, I checked to make sure that the Sonos speaker was found by the plugin and then tried to add a new entry.....it worked!
Not sure if this is related or not but I noticed in Rich’s post for HS3 .376 that he mentioned “Fixed the INI settings so writing a new value to a section that does not exist will now create the section”. Think this might have been the issue? Maybe not....it is working for others, just wasn’t working in mine.
  #26
Old October 12th, 2017, 03:07 PM
OverSeer
That is exactly what was happening. Can you delete entries now?
  #27
Old October 12th, 2017, 03:11 PM
The Profit's Avatar
Seer Deluxe
Just tested that, yes I now get the “Are you sure” pop up that I haven’t seen before and when I clicked submit, it deleted it.
  #28
Old October 13th, 2017, 02:37 AM
The Profit's Avatar
Seer Deluxe
Dirk, just want to say thank you for your help resolving the issue I had....and thank you for all the work you do to keep our homes automated with great music!
HTML code is Off
Sonos Linkgroup as Speaker Client for BLLock? mda BLLock (3P) 2 July 2nd, 2017 09:19 PM
Table top remote for table lamps lodi HomeSeer General Discussion Area 7 February 4th, 2017 02:17 PM
LinkGroup Issues? matt246 PI-SonosController (3P) 10 October 19th, 2016 06:17 AM
Cannot create linkgroup jello4 PI-SonosController (3P) 1 October 7th, 2014 04:04 PM
Error ***:ConfigIO - Unable to display configuration dialog because: Unable to show m connoleg ACRF Processor (3P) 5 October 16th, 2006 02:29 PM
