The BLCapture Plug-in for HomeSeer allows the user to capture images and videos from a capture device. This plugin is written in VB .Net 2.0 and requires Homeseer Version 2.1.0 or later.
NOTE: I recommend that you download and try out the plug-in first before buying because it works for some users but not for others.
- Allows user to capture still images from capture device.
- Allows user to capture moving video from capture device.
- Allows user to capture audio in the moving video.
- User can select a video compression to use when capturing moving video. NOTE: Some video compressions do not work with all capture devices so it may cause HomeSeer to lockup.
- User can select an audio compression to use when capturing moving video. NOTE: Some audio compressions do not work with all capture devices so it may cause HomeSeer to lockup.
- Allows plug-in actions to be added to HomeSeer events to capture from device.
