I am new to this plugin and am trying it.
I have some Wemos devices and add one of them , put code in it and now i can switch a relais On and Off. Works perfect.
With another wemos i want to make a dimmer device to dimm a ledlight , but when i add a device and select NodeMcu as type, then the Pwm tab disappears in the setup.
So i cant make a dimmer/pwm device.
Is this a restriction of the plugin, or is it possible in another way?
Plugin is latest beta 1.0.0.141 On Hs3/Windows 10.
Egbert
Egbert
