NorthQ 9021 power reader no longer working
    I've had this for a few years, it's always been working as expected but back in june it stopped reporting kWh. So I changed the batteries, as I expected that to be the problem, but no. I've tried excluding and including it, and even reset it, but it only reports battery status, not kWh. The LED on the unit flashes as it should whenever the power meter flashes - all parameters are set correctly.
    So that got me wondering if something has happened to the z-wave plugin that broke the support for the NorthQ? I'm currently running .137, just upgraded from .133 to se if it made a difference (it didn't).
    Here's the inclusion from the log as well as the devices and the root info (attached):
    aug-13 11.27.37 Z-Wave 2 out of 2 Child devices of node 91 were created successfully.
    aug-13 11.27.37 Z-Wave Adding Z-Wave Node 91 kW Hours as an Energy tracking device.
    aug-13 11.27.34 Z-Wave Z-Wave Node 91 NorthQ Meter supports having its date/time set. Current TimeZone is Vest-Europa (sommertid) with a UTC offset of 2h, 0m and a Current UTC time of 13.08.2017 09.27
    aug-13 11.27.34 Z-Wave Root Node Device Z-Wave Node 91 NorthQ Meter was created for node 91 on network
    aug-13 11.27.33 Z-Wave Node 91 Meter is Supported for Electric_meter, Type ELECTRIC_kWh, Scale is ACCUMULATED
    aug-13 11.27.33 Z-Wave Node 91 is Z-Wave version: Lib: 2.78 App: 2.153
    aug-13 11.27.33 Z-Wave Node: 91 Supports Class(es): BASIC_V2, BATTERY, WAKE_UP, FIRMWARE_UPDATE_MD_V2, TIME_PARAMETERS, METER_V3, CRC_16_ENCAP, CONFIGURATION_V4, MANUFACTURER_SPECIFIC_V2, MANUFACTURER_PROPRIETARY, VERSION_V2, METER_TBL_MONITOR
    aug-13 11.27.33 Z-Wave Z-Wave manufacturer information for node 91, ID: 150=96H (NorthQ), Type: 1=1H, ID: 1=1H
    aug-13 11.27.33 Z-Wave Synchronize nodes finished. Number of device nodes to be created/added = 1
    aug-13 11.27.32 Z-Wave JINs: Controller firmware version: 4.32
    aug-13 11.27.32 Z-Wave JINs: Controller Manufacturer: Express Controls, ID=0x2, Type=0x5
    aug-13 11.27.31 Z-Wave Done. Node 91 Added.
    No one with a NorthQ that can confirm/not confirm?
      Bump
