HS3 on Synology
    HS3 on Synology
    I posted earlier to see if anyone had HS3 working on Synology. I was wondering if anyone had any luck
    Greg
    Your best bet will be to install the debian-chroot package from synocommunity and then install HS3 in the Debian chroot jail.
    I'm doing it at the moment, and will let you know how I get on. I'm a Linux newbie!
      I now have it running on my DS412+, although I'm still getting used to Chroot and how it actually works. I'm sure there is more tweaking to make it work.
        HS3 Synology and Insteon 2413U
        Finally had time to figure out how to install on my Synology, and...Works Great! I also have the insteon plugin working with my 2413u..... Just wish there were more plugins (Global Cache).
        Britkat,
        How are you starting HomeSeer? Are you using a startup script? I have seen one located in the forum here...wonder if it will work.
        http://board.homeseer.com/showthread.php?t=165690
          Synology
          It's all working now on the synology, chroot debian startup script, insteon and itach scripts!
            Sorry for digging up and old post, but are you still using HS3 on your Synology NAS? I like to test a similar setup (on a 415+) and was wondering if it was worth the try. Is it stable? How is the performance?
            Do you have any instructions on installing? Or anything that could help a first time Synology user? Thanks!
            stefxx
            stefxx
              +1
              Any instructions on doing this, i am not a linux guy so don't know where to start.
              Any help would be great
                +1
                Also interested.
                  OK got it running here but no zwave with my new zwave.me plus stick... anyone else managed to get it working?
                    HS3 on Synology
                    deanrparry, Any chance you might post instructions on how you got this installed?
                    Thanks in advance
                      Interested this as well...
                      d
                      Greg
                        +1
                        Interested to.
                        Greig.
                        Scripts =
                        Various
                          I have it running for a few months now on a 415+. Getting everything to work took a long time and effort, which I did not completely document. Also, I run everything from an USB3 stick to not interrupt the Synology disk standby feature. If someone is interested I can try to backup the stick and make it available for others. Again, this will only work on the 415+.
                          No other software needs to be installed on the Synology to work (all is on the USB stick). It includes mono, usb2serial drivers and other components (for instance for the energy graphs to work).
                          stefxx
                            Hi can you send me the backup?
                            I have a DS415+ and a DS716+ I'd like to try this on. Any instructions you give would be helpful. I already use the Mono (beta) package and installed Debian Chroot just now to try this myself.
                              How to use DOCKER on Synology
                              you can install Homeseer via DOCKER
                              it's quite simple.
                              Open DSM
                              > Install Docker (if you don't already have it)
                              > Within Docker, go to REGISTRY tab and in the search box type "Homeseer"
                              > Download the image "bradsjm/homeseer3:latest" (this may take a few moments)
                              > On the IMAGE tab click the homeseer image then click launch button
                              > within the new window that pops up labeled 'Step 1', set the container name (anything you choose is fine)
                              > Port Settings: Local Port | Container Port
                              - HTTP 80 | 80
                              - HSTOUCH 10200 | 10200
                              NOTE: You can select automatic, however each time the container loads it will change the local ports
                              > Click next to proceed.
                              > On 'Step 2' page: You can set limitations, but it's not required.
                              - Select Auto Restart (this will help in case of power outage)
                              > On 'Summary' page: Click ADVANCED SETTINGS button
                              > [This part i'm still having trouble with so hopefully someone else can help here]
                              You need to map file locations, regardless if you do this or not, you can still run the container and it will work, but for custom plugins you need to do this.
                              >Once you are done run the container and navigate to http://YourDSip:localport (as specified by the docker container)
                              I hope this helped.
