is there any way that you can update device values as they are sent across? I am using the MCS 1 wire for Xap and it works great except that this plugin here will not update the device values with my temperatures.. one of my applications requires use of a device values and requires pretty fast updates so I run into issues as I cant trigger based on a device string in homeseer directly, I need to trigger a script when the value of the temp changes in any way.. plus perform numerical actions on the temperature value itself.
-Christopher
-Christopher
