After upgrading to HS 2.1.104.0 I have a problem with events. All of my Ocelot events that have Device Status Change as the trigger and use an Interface I/O Digital Input as the device continue to work fine, but if I edit the event, these devices are no longer in the pulldown menu. I can't create new events either.
I found a work around by making the condition Device Value Change to 1 and change the variable type from Digital Input to Interface Variable. This works, but I will see 0 and 1 as a status now instead of On and Off.
This sounds like a HS bug so I posted it here. Is there a fix?
