Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Blade Plug-Ins > BLSpeech (3P)
BLSpeech (3P) Discussion of BLSpeech plug-in
Old September 9th, 2016, 06:43 PM
Jobee Jobee is offline
Special Tag source= not working
After finally seeing how to work BLSpeech and BLRussound, I setup a test event (below). When the back door closes, the kitchen speakers come on and speak something.
In my setup, my Russound ST2 tuner (XM) is input/source 1. AM/FM is input/source 2 and my speech is input/source 3.
My event uses the special tags to set the priority, set the speaker (and turn it off at the end), set the volume and set the source.
When it runs, the priority, speaker and volume all work. However the source does not. The speaker comes on at the last source used. The BLSpeech directions say to use source=<number of source you want>, in my case 3.
Does anyone have this working? I also tried it with source=speech (which is the name of my source.
------------------- Log ----------------------
Sep-09 18:06:13 TTS Speak: (SPEAKEFAULT):Welcome home. It is currently 6:06 PM
Sep-09 18:06:13 EnvisaLinkAdemco INFO Z02 Back Doors status change: Closed
Sep-09 18:06:13 Event Event Trigger "Announcements Greeting when Back Door Opens/Closes"
I also have the debug logs for both Russound and Speech.
For grins I removed the |off from the speaker, and tried again. This time it worked, but it did not turn off the speaker.
HS3Pro on Win2012R2
Aeotec, Cooper, Cree, GE/Jasco, Intermatic, LIFX, Fortrezz, OSRAM, RCS, Trane, Zooz
BLBackup, BLGData, BLRussound, BLSpeech, HSTouch, InvisaLink, HSBuddy, IFTTT, NetCAM, PHLocation, Pushover 3P, Random, UltraLighting3, weatherXML, ZigBee, Z-Wave
Old September 9th, 2016, 09:09 PM
sirmeili sirmeili is offline
Super Seer
Ok, so I'll tell you How I have it set up. I never use the "source" tag (never had to). in the first image below you'll see my settings for BLSpeech for the BLRussound section. Also look at the section below. Once these are set, you don't "need" to use the source tag. As a matter of fact if you set the default speaker or zone, you don't need the speaker tag either.
Also note that "Russound Zones Return to Original State After Speaking" is checked. This is great. So if I'm listening to music in the master bathroom, it will change zones, speak, then return to my original source (and volume). If it is off, it will turn on the zone to the correct source, then turn it off after speaking, making sure to return it to the previous source as well. I never intentionally set any of my zones to "House" (which is the same as your Speech one).
Final note, I never set the default volume. I assume if I don't set it and don't set it in the tag, it will use whatever volume it was already at (or the turn-on volume for that zone). I think I always use the volume tag though.
Old September 9th, 2016, 09:32 PM
Thanks for the input.
I have the Russound integration boxes checked, so good there.
I have various exit points so I cannot set a default speaker or zone, so I left that in the tags.
I did use the default speech source and removed that special tag.
So my speech text now just has:
{priority=high,speaker=Living Room,volume=50,} Welcome home. It is currently $$time
Now it sets the correct source, completes the speech and returns to the pre-speech source and volume. I like this so if I do have the music on, it does the speech and then returns to what was happening.
Thanks for your help.
Old September 9th, 2016, 10:09 PM
Super Seer
No problem! Always glad to help when I can
Sent from my XT1585 using Tapatalk
Old September 10th, 2016, 10:18 PM
I have been working with this on and off today. If the Russound is already on and on XM and a speech needs to happen, it does everything correct. It flips to source 3, does the speech at volume 50 and then goes back to XM at the volume it was at. Happy with this part.
But when the Russound is off and a trigger happens, it turns the correct speaker on, sets the speech volume and source and does the speech. This is where the problem then happens. If the Russound was on source 1 but off, when it finishes speaking, it sometimes leaves the source on speech (does not set it back). Also (and the most troubling) is that it seems to turn the power off but the keypad screen stays on (see picture below). This screen part happens every time. The only way to get the keypad to fully shut down is to turn it on again and turn it off.
Old September 11th, 2016, 07:11 AM
S-F's Avatar
S-F S-F is offline
This is a bug. Try to capture debug logs for both BLSpeech and BLRussound when it happens and get them to Blade.
Originally Posted by rprade View Post
Old September 11th, 2016, 03:10 PM
Got the logs... of course they are large.
Blade - let me know where to send the zip file.
Michael
Old September 11th, 2016, 03:21 PM
S-F's Avatar
S-F S-F is offline
Michael
Go to his help desk (link in his signature) open a ticket, describe the issue and then attach the logs zipped up.
Old September 11th, 2016, 06:35 PM
Ticket 969 created and logs uploaded. I thought you said it was a known bug so I hope I did not confuse things by opening a new ticket.
Michael
Old September 11th, 2016, 07:57 PM
Blade's Avatar
Blade Blade is online now
OK I will try and duplicate this here now that I have some zones hooked up to my CAV66
I only have 1 source right now
Bear with me on this - I am still trying to get back to normal after the move to the new house
Cheers,
Bob
Old September 11th, 2016, 09:26 PM
S-F's Avatar
S-F S-F is offline
Michael
It is a known bug but because it's intermittent I've had a hard time logging it. I'm glad you were able to catch it.
Old September 13th, 2016, 06:51 AM
Blade's Avatar
I will be adding more zones and sources this week so I am aiming for trying to duplicate this on the weekend - I do have to do some work this weekend for my job as well but I am hoping to get time because I really want to nail this down
Old September 15th, 2016, 05:23 PM
Blade's Avatar
I have 7 zones and 3 sources now and I am seeing the same issue with the keypad being left on but plugin thinks it is off
Now I can try and figure this one out
Old September 15th, 2016, 06:41 PM
S-F's Avatar
S-F S-F is offline
For the record I have never seen that. I have from time to time seen the source not switch back to where it was originally but the zone always turns off.
Old September 15th, 2016, 08:54 PM
Blade's Avatar
Can you attach your hspi_BLSpeech.ini zipped
Old September 16th, 2016, 12:20 AM
done
File Type: zip hspi_BLSpeech.zip (926 Bytes, 4 views)
Old September 16th, 2016, 06:32 AM
Blade's Avatar
I have been seeing zones stay on when they should go off. I can duplicate that pretty much every time. I need to play with some delays. I think the calls are being sent to the Russound too fast and it might be missing some. The devices in BLRussound say they are off but the keypad is on.
I think I need to bundle the commands for a speech action and then perform them at once and see what happens. I will play with this and let you know when I have something to try out.
Old September 16th, 2016, 11:46 AM
having/fixing the delay would be good. I have two events that happen every morning and even though I put a delay on one of them, they still sometimes bump into each other and one does not work. and on the speak side, I have to delay the start of the speech or it does not catch the first part of the first sentence. So the speaking starts before the unit fully turns on.
Old September 16th, 2016, 11:52 AM
S-F's Avatar
S-F S-F is offline
@Jobee, what Russound system do you have? I have a CAA and don't see these issues even though I make great use of BLSpeech.
Old September 16th, 2016, 12:16 PM
Super Seer
I see them sometimes with my CAA66. I often find my Foyer and Guest bathroom zones on even though they should only ever be off except during "announcements"
Special tags for more than one source, zone, volume, etc? S-F BLSpeech (3P) 1 June 2nd, 2014 03:17 PM
Play Special Greeting, Hang Up Not Working cfischer HomeSeer Phone 2 September 25th, 2011 03:03 PM
Armed by Special mark_anderson_us BLDSC (3P) 31 August 7th, 2011 11:16 AM
Modem Special Pete HomeSeer Phone 0 December 4th, 2007 10:12 PM
Another McD's special.... glt WAF NetCallerID (3P) 2 August 21st, 2004 09:48 AM
