Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Blade Plug-Ins > BLSpeech (3P)
BLSpeech (3P) Discussion of BLSpeech plug-in
Old September 18th, 2016, 03:24 PM
rprade's Avatar
rprade rprade is online now
Compatibility with Sonos plug-in
I am using a handful of Android clients and Dirk's Sonos plug-in for speech. I am not using the HS speaker client.
Can this plug-in be configured to use a Sonos linkgroup as a speaker client? If anyone is using it to work with HomeSeer clients as well as Sonos clients could I get some tips on how to setup a BLSpeech speaker for use with the Sonos plug-in?
Randy Prade
Aurora, CO
Prades.net
Old September 18th, 2016, 05:51 PM
S-F's Avatar
S-F S-F is online now
I do not believe that any integration is possible. Particularly since you aren't using Speaker.exe. It's a shame since BLSpeech is the be all and end all for what it does.
Originally Posted by rprade View Post
Old September 18th, 2016, 06:39 PM
rprade's Avatar
I suppose I could run speaker.exe. When I'm running on a VM there is no hardware to support it,but I think it will load.
How does that make a difference? Is it in the Sonos plug-in or in BLSpeech?
Old September 18th, 2016, 09:47 PM
S-F's Avatar
Rqndy, I'm in a bit of a tight spot ATM as my desktop has been down for a while (hence infrequent and short post as of late. Phone only) so I can't properly break it all down just now. New machine this week though.
I think,
The short answer is you are not going to be able to use BLSpeech. Unfortunately.
The good news is that you can sell the Sones stuff for a profit and get a Russound system!
Old October 26th, 2017, 08:01 PM
MNB's Avatar
MNB MNB is offline
Randy, I know that this thread is dated, did you ever figure out if BLSpeech works with SONOS? If yes what did you have to do and in what manner did you use BLSpeech? Mike
PS Looks like Colin is pimping the Russound system again... I had a similar comment in regards to SONOS.
Computer: CUK Intel NUC7i7BNH
Op System: Windows 10 Pro - Work Station
HS Version: HS3 Pro Edition 3.0.0.435
Plug-Ins: BLBackup, BLGData, BLRoombaWifi, Device History, EasyTrigger, ImperiHome, Nest, PHLocation, Pushover 3P, Restart, Sonos, UltraCID3, UltraWeatherWU3, Z-Wave, and Jon00 scripts.
Old October 26th, 2017, 09:04 PM
rprade's Avatar
I could never get it to work. It might, but I ran out of patience about the same time as the trial ended.
I decided to write a script that builds linkgroups, sets levels, sets source and enables the chosen clients. The script looks to an ini file for phrases. I then run an event that runs the script with two parameters, the tag fr the speech phrase and an overall volume "adder". The volume adder can be an integer from -99 to +99 to adjust the overall level to a minimum of 1 or a maximum of 99. By default the script will run all 8 Sonos devices at levels set by virtual devices. Within the event that calls the script, I can disable any of the clients I want quiet, use an adder integer if I want the announcement louder or softer than usual. There are two types of spoken phrases, an "announcement" or an "alert" An alert is automatically louder than an announcement as set by another virtual device. Within the text strings in the ini file I can use delays and set voices.
I can post a lot more details if anyone is interested.
Old February 17th, 2018, 06:56 PM
Summerguy's Avatar
Summerguy Summerguy is offline
Any news on this ? Is this possible to use blspeech with Sonos Unit?
I do not understand why i cannot simply put $SONOS$All$ in the speach plugin.
am am able to use the $SONOS$All$ command in blgdata for speakeing calendar events.. what is different here ?
thanks
Matt
Old February 17th, 2018, 09:15 PM
Blade's Avatar
Blade Blade is offline
thanks
Matt
Have you tried it in BLSpeech?
Show me what you are doing in BLGData
Cheers,
Bob
Old March 1st, 2018, 09:05 PM
Summerguy's Avatar
Hi blade. I was not subscribed to this post, so sorry for the delay.
I use this directly in a handler :
HS[SpeakClient~This is a test~$SONOS$ALL].
or
HS[SpeakClient~This is a test~$SONOS$Hallway].
etc.
And this works.
Old March 1st, 2018, 09:20 PM
Blade's Avatar
If you are using Speak with BLSpeech installed and running as a speech proxy then BLSpeech is speaking the message for you
Maybe I am missing something... What exactly are you trying to do in BLSpeech that it is not letting you?
HS3 System Plug-in Compatibility List macromark HS3 / HS3PRO Discussion 15 September 29th, 2014 09:13 AM
Plug-in status and compatibility? mterry63 NUVO 12 March 11th, 2014 01:07 PM
Plug-in status and compatibility? mterry63 Russound 3 November 30th, 2013 05:26 AM
Plug-in compatibility with HSPro SeattleGirl5122 HomeSeer General Discussion Area 7 September 14th, 2009 09:47 PM
Plug-In Compatibility Mark L Elk M1 Plug-In 0 October 4th, 2005 08:44 PM
