After downloading the subject plugin, it appears in the list of plug ins with an OK status. The Instance column says to See plug-in config. The config screen is as follows...
Error: System.InvalidCastException: Conversion from string "60.0" to type 'Integer' is not valid. ---> System.FormatException: Input string was not in the correct format at System.Int32.Parse (System.String s) [0x00000] in :0 at Microsoft.VisualBasic.CompilerServices.IntegerType.FromStrin g (System.String Value) [0x00000] in :0 --- End of inner exception stack trace --- at Microsoft.VisualBasic.CompilerServices.IntegerType.FromStrin g (System.String Value) [0x00000] in :0 at Microsoft.VisualBasic.CompilerServices.Conversions.ToInteger (System.String Value) [0x00000] in :0 at HSPI_APCUPSD.HSPI.get_UPSUpdateInterval () [0x00000] in :0 at (wrapper remoting-invoke-with-check) HSPI_APCUPSD.HSPI:get_UPSUpdateInterval () at HSPI_APCUPSD.hspi_config_page.GetPagePlugin (System.String PageName, System.String user, Int32 userRights, System.String queryString) [0x00000] in :0
APCUPSD on my Win 10 PC installed and configured without a problem and displays UPS status detail when the systray icon is executed.
Thoughts?
Bob
Thoughts?
Bob
