I cannot get Updater to work. I keep getting a Parser error. Anyone else?
Updater Not working
Try loading the newest release version which is 2.2.66. Which is available here: http://board.homeseer.com/showthread.php?t=123980
Error installing HS2
I want to install HS on a stand-alone computer. This would be called my HS computer.( with nothing else on it). The install of HS2 worked just fine, but when i want to acces the installer tab, to re-intall all my plugins, the following error occured:
add assembly="System.Runtime.Serialization.Formatters.Soap, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
add assembly="sysglobl, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
add assembly="SKCLNET, Version=4.2.1.12, Culture=neutral, PublicKeyToken=D5770E63406D04A0"/>
<add assembly="System.Configuration, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A
I did read on this forum to copy the "SKCLNET.DLL" to the HTML/BIN dir. but that does not worked for me. So it's a brand new install on a brand new configgured computer, there is not much I could do wrong :-)
Has any one got an idea ?
Wil
JustOneMore
My updater is not working either, getting similiar err. I installed full version of 2.2.0.66 this morning .
Server Error in '/' Application. <HR width="100%" color=silver SIZE=1>
Configuration Error
Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
Parser Error Message: Could not load file or assembly 'SKCLNET, Version=4.2.1.12, Culture=neutral, PublicKeyToken=d5770e63406d04a0' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
Source Error:
<TABLE width="100%" bgColor=#ffffcc><TBODY><TR><TD><CODE>
Line 37: <add assembly="System.Runtime.Serialization.Formatters.Soap, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>Line 38: <add assembly="sysglobl, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>Line 39: <add assembly="SKCLNET, Version=4.2.1.12, Culture=neutral, PublicKeyToken=D5770E63406D04A0"/>Line 40: <add assembly="System.Configuration, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/></assemblies></compilation>Line 41: <!--</PRE></CODE></TD></TR></TBODY></TABLE>
Source File: C:\Program Files\HomeSeer 2\html\updater\web.config Line: 39
Assembly Load Trace: The following information can be helpful to determine why the assembly 'SKCLNET, Version=4.2.1.12, Culture=neutral, PublicKeyToken=d5770e63406d04a0' could not be loaded.
WRN: Assembly binding logging is turned OFF.To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.Note: There is some performance penalty associated with assembly bind failure logging.To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].</PRE></CODE></TD></TR></TBODY></TABLE>
</P><HR width="100%" color=silver SIZE=1>Version Information: Microsoft .NET Framework Version:2.0.50727.832; ASP.NET Version:2.0.50727.832 <!-- [FileLoadException]: Could not load file or assembly 'SKCLNET, Version=4.2.1.12, Culture=neutral, PublicKeyToken=d5770e63406d04a0' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040) at System.Reflection.Assembly.nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection) at System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) at System.Reflection.Assembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) at System.Reflection.Assembly.Load(String assemblyString) at System.Web.Configuration.CompilationSection.LoadAssemblyHelp er(String assemblyName, Boolean starDirective)[ConfigurationErrorsException]: Could not load file or assembly 'SKCLNET, Version=4.2.1.12, Culture=neutral, PublicKeyToken=d5770e63406d04a0' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040) (C:\Program Files\HomeSeer 2\html\updater\web.config line 39) at System.Web.Configuration.CompilationSection.LoadAssemblyHelp er(String assemblyName, Boolean starDirective) at System.Web.Configuration.CompilationSection.LoadAssembly(*** emblyInfo ai) at System.Web.Compilation.BuildManager.GetReferencedAssemblies( CompilationSection compConfig) at System.Web.Compilation.WebDirectoryBatchCompiler..ctor(Virtu alDirectory vdir) at System.Web.Compilation.BuildManager.BatchCompileWebDirectory Internal(VirtualDirectory vdir, Boolean ignoreErrors) at System.Web.Compilation.BuildManager.BatchCompileWebDirectory (VirtualDirectory vdir, VirtualPath virtualDir, Boolean ignoreErrors) at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPa th virtualPath) at System.Web.Compilation.BuildManager.GetVPathBuildResultInter nal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithN oAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.Compilation.BuildManager.GetVirtualPathObjectFact ory(VirtualPath virtualPath, HttpContext context, Boolean allowCrossApp, Boolean noAssert) at System.Web.Compilation.BuildManager.CreateInstanceFromVirtua lPath(VirtualPath virtualPath, Type requiredBaseType, HttpContext context, Boolean allowCrossApp, Boolean noAssert) at System.Web.UI.PageHandlerFactory.GetHandlerHelper(HttpContex t context, String requestType, VirtualPath virtualPath, String physicalPath) at System.Web.UI.PageHandlerFactory.System.Web.IHttpHandlerFact ory2.GetHandler(HttpContext context, String requestType, VirtualPath virtualPath, String physicalPath) at System.Web.HttpApplication.MapHttpHandler(HttpContext context, String requestType, VirtualPath path, String pathTranslated, Boolean useAppConfig) at System.Web.HttpApplication.MapHandlerExecutionStep.System.We b.HttpApplication.IExecutionStep.Execute() at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)-->
JustOneMore
Thanks for the reply Rupp, but that didn't do it either.
Firstly it was already in both locations at apparently the same size.
Tried MOVING from root to /html/bin (loosing it in root). This caused err on HS startup - some kind of scheduler problem. So I put it back the way it was. Then COPIED from room to /html/bin. That put me back to where I was with the above posted config err.
noisyoldradiator
Same problem
I have the same problem and I am offered the following fix:
The problem is I don't have that registry value.
Any Ideas?
JustOneMore
I got that same fix as well, I think my pasting was truncated. I'm not really able to follow that repais though. Either it's not there or above my head. Both are equally likely!!!
What stinks is I decided to do a FRESH install, and now I can't get all my PAID plugins back online. Wifey is gonna have my butt
Guys,
Try deleting your entire HomeSeer folder (after backing up) and then do a reinstall of your Microsoft 2.0 .net framework and then reinstall using the full HomeSeer installer available here: http://www.homeseer.com/downloads
JustOneMore
Aegis1 - That did the trick. Updater working now, and I can almost swear startup is tons faster!!!!
Rupp - Thanks. Aegis1's seemed faster, but was ready to try anything.
Thanks guys
