I am going to assume that this is the frequency that the plug in will poll the module? By default it is set to 0. When would you need to set this value to other than 0?
Polling interval question
Originally posted by Ken LaCapria View PostI am going to assume that this is the frequency that the plug in will poll the module? By default it is set to 0. When would you need to set this value to other than 0?
Another alternative it to use polling for eveything in case a status change msg is missed.Mark
HS3 Pro 4.2.19.5
HS3 Pro 4.2.19.5
HS3 Pro 4.2.19.5
