Hi all,
so, yesterday, I received a new Z-Wave home theater remote which claimed to be able to control thermostats as well as zwave lighting, etc.
So, I tried to pair 2 of my 3 thermostats with the remote, but after unsuccessful tries, I realized that HomeSeer no longer "saw" the thermostats. I figured my only option was to remove them and re-add them. I used the "replace device" feature with no success, and tried to follow the instructions to "simply delete the new Z-Wave device that HomeSeer created and change the Node Number on the old device to the new one". Well, everything seemed to be OK, until...
Whenever I go to my climate page in HSTouch, each thermostat displays "N/A" even though the page to select the thermostats has the correct temp/etc. When the thermostats are selected, the following errors are logged:
I've tried restarting HomeSeer, re-adding the nodes within HomeSeer and from the Z-Stick itself, restarting the HomeSeer computer, etc, to no avail!
Any help is appreciated!
Error in StatName, Object reference not set to an instance of an object. Error in HSPI.NTemps, Object reference not set to an instance of an object.
