Hello,
In a previous post you provided me a beta release (3.0.6.31), which made the Keypad and Fanlinc work in perfect harmony - thanks. However I found one small detail with Alexa voice control that is not ideal.
Setup (See screenshot below):
The Keypad buttons are linked to Fanlinc high, medium, low, and off. The keypad "Sync linked responder devices" box is checked so the keypad leds and fanlinc are all working together. If I say things like "Master fan medium" everything works perfectly.
Problem:
The only small problem remaining is that if I say "Master fan off" the fan turns off but the keypad leds do not change. If I say "Mater fan on" the fan turns off and the off led does work. This behavior makes perfect sense with this setup, but I obvious would like to use the "off" keyword. So I need the Keypad off led to activate when it is turned off (Not on). Perhaps this is the button mode "non-toggle off" from the tooltip, but is not actually available in the combobox. Could you help with this issue?
Problem:
