Sorry if this is an old question, this section of the message board is large.
I'm using an Insteon HUB (2245-222) with HS3. Prior to using HS3 I created some scenes using the HUB's iPhone app. I just created my first HS3 group and it appears that turning on the HS3 group also fires off a different old scene defined in the HUB. I assume I have overlapping scene/groups...
Was I supposed "read" in the HUB's scenes before creating HS3 groups in the plug-in? I see a few utility functions in the plug-in config, not clear if I should have used one of them to synchronize the HUB and the plug-in's database.
