Seems to work, but with a little strangeness - I shut down HS, copied the file over, and restarted. I went into UPS3 and selected NUT and usbhid. The home screen showed USP3 as enabled, but it didn't start updating until after I started poking around in APCUPSD status and events - not sure what was happening (my status update interval is 1 minute, and my network monitoring interval is 3 minutes (?)), so I deleted UPS3 and recreated it - same thing. Maybe a function of how often the EX4 is updating?
Also, I guess I need to go in and manually delete the status events from the home page that NUT doesn't support. The plugin creates all events when a new instance is created, and then changing to NUT leaves the events that don't apply?
Jim Madigan
Jim Madigan
