I've approached this subject before, but have now hit it head on.
HS3 needs to have redundancy features. It should be possible to run HS3 from two different machines, one as primary, one as secondary, and have the secondary go down when the primary stops communicating with it.
I ran into this situation recently. I was running HS3 from an ASUS tablet, and it had a fan go out. While I was trying to decide what to do with the tablet, I moved HS3 to my main PC. A few weeks later, that PC went down with a UEFI issue. That left me without any home automation. I've since installed a new fan on the ASUS and it is back up and running, and the PC is recovered - the secondary disk had to be recovered, though, and this process took a week or so.
So, that got me thinking about what to do in the future. The "best" solution is a dual mode for HS3. Other things I've thought about:
-- Install HS3 to an external drive that could be swapped to a different computer if needed.
-- Set up a VM on an external drive and run HS3 from that.
I can say that running HS3 from two different places works, though I didn't stay in that state long enough to see what would happen if an event was generated, etc. I know that devices can only be connected to one Z-Wave hub (may not be using the correct term), but I don't think that there is a technical restriction on how many controllers (HS3) can connect to that hub.
Any thoughts???
David
Any thoughts???
David
