Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > Insteon Plug-in (Mark Sandler)
Insteon Plug-in (Mark Sandler) Discussions related to Mark Sandler's 3rd parth plug-in for controlling Insteon devices via Smarthome's PLM interfaces (the 2412 & 2413 series controllers)
Old August 1st, 2010, 10:46 AM
timmymac123 timmymac123 is offline
Seer Plus
Windows 7 and PLC 2414U do not seem to work
I just did a fresh install of Win7 Home Premium.
I am now trying fruitlessly to get HS2 to work with INSTEON and X-10 devices that worked under XP.
My Insteon/X-10 network consists of:
1. linked (to each other) access points on different phases on different floors of the house.
2. 2414U (FW:2.13), USB PLC
3. About 10 Insteon devices
4. About 10 X-10 devices
I have installed HS2 and did an immediate upgrade to 2.4.0.11 (current as of this writing). I used the PLC and it shows up as 1.1.52.1
No matter what I try, I am unable to communicate with any other device period...X10 or INSTEON.
I have been (and still am) searching for viable solutions, but as of yet have not found any.
Does anyone have any clue as to why I am having such difficulty?
I have all the Device ID's. I have tried tap-adding and manual-adding. Neither way produces any results...unable to communicate.
More info, log file and results after trying to manually add a device:
Insteon Plug-in Configuration - HYBRID PLC VERSION 1.1.52.1 In PLC/SDM Mode
The Insteon device at 07.CC.4D did not respond. Please check to make sure the address is correct and that the device is powered-up. The device was not registered.
Thanks.
--tmac
Old August 1st, 2010, 11:07 AM
Rupp's Avatar
Rupp Rupp is offline
OverSeer
I thought that the latest versions of the Insteon plugin dropped support for the PLC. What version of the Insteon plugin are you running?
-Rupp
Old August 1st, 2010, 11:15 AM
Seer Plus
It was mentioned twice in the original posting...1.1.52.1 (it is installed by default and according to "updates" it is also current)
Old August 1st, 2010, 06:17 PM
macromark's Avatar
macromark macromark is offline
HomeSeer Technologies
I don't believe the Smarthome Device Manager (SDM) software is Windows 7 compatible. Might be a good time to dump the 2414U and switch to one of the new 2413U dual band PLM's.
Old August 1st, 2010, 10:36 PM
Seer Plus
Go figure...Smarthome pulling that crap too.
As far as I could tell, it was simply not compatible with 64-bit windows-7.
...at least that is what the product page for the 2414U shows.
I have a 2413U on order, hopefully it ships from a nearby warehouse.
--tmac
Old August 10th, 2010, 09:04 PM
Seer Plus
Working now...with outside help
Well, as much as I hated to do it, I paid Smarthome another $80 for a 2413U.
All appears to be working and the device seems (so far) to have much better reliability communicating with all the devices I have (both X10 and Insteon)
Tags
insteon, plc, sdm, windows7
HTML code is On
