I run mine behind an IP/Serial converter so I'm communicating via LAN rather than directly to a port. When I get a chance I'll connect it directly to a port to see if I get the same behavior as you.
xapmcsADIOcelot - ADIOcelot xAP Node
I tried the xapmcsADIOcelot directly to COM port and it behaved just as with the direct IP connection. I have some startup error messages related to the scripting support that is ony partially implemented but the basic variable and SECU updates are seen and the variables are being polled at 2000 milliseconds per the setup.
What polling rate are you using? You can enable the low level communications log from the setup page and take a look at the serial traffic.
Here is my startup log
mcs.AdiOcelot.MCS5 2005-11-10 22:17:15 | xapmcsAdiOcelot | Using xAP port 32775
mcs.AdiOcelot.MCS5 2005-11-10 22:17:16 | xapmcsAdiOcelot | InitFilterDictionary Line 30 Object variable or With block variable not set
mcs.AdiOcelot.MCS5 2005-11-10 22:17:16 | xapmcsAdiOcelot | InitDeviceDictionary Line 30 Object variable or With block variable not set
mcs.AdiOcelot.MCS5 2005-11-10 22:17:16 | xapmcsAdiOcelot | InitScriptControl -2147024809 Line 60 The object cannot be nothing.
mcs.AdiOcelot.MCS5 2005-11-10 22:17:17 | xapmcsAdiOcelot | Version 2.0.25 Registered with Setup
mcs.AdiOcelot.MCS5 2005-11-10 22:17:17 | xapmcsAdiOcelot | Initializing X10 Interface on port 8
mcs.AdiOcelot.MCS5 2005-11-10 22:17:19 | xapmcsAdiOcelot | Using Comm Port 8
mcs.AdiOcelot.MCS5 2005-11-10 22:17:19 | xapmcsAdiOcelot | Found CPU-XA/Ocelot
mcs.AdiOcelot.MCS5 2005-11-10 22:17:20 | xapmcsAdiOcelot | Ocelot IR size: 1024
mcs.AdiOcelot.MCS5 2005-11-10 22:17:22 | xapmcsAdiOcelot | Unit found: SECU16 Addr: 1
Well I almost got it working through the terminal server. It identifies the modules, and seems to communicate. Except..
In the log I get:
1/25/2006 11:34:24 PM TCPCOMM
1/25/2006 11:34:24 PM 2A 00 00 A9 1B 00 2F C3 2C 17 CD 24 13 3A 35 A0 B7 20 05 21 35 A0 36 01 3A 35 A0 6F E5 3A 34 A0 4F 3A 33 A0 C3 FD 17 2A 1B A0 36 00 CD BA 27 26 00 22 13 A0 3A 22 A3 5F CD 4B 43 3A 23 A3 5F CD 4B 43 3A 13 A0 5F CD 4B 43 C3 2C 17 CD 24 13 ED 5B 39 A0 C3 82 17 CD 24 13 3A 35 A0 32 1E A6 2A 39 A0 22 2E A3 C3 2C 17 CD 24 13 2A 3B A0 E5 3A 34 A0 4F 3A 33 A0 5F C3 6F 17 CD 24 13 21 00 00 18 EC CD 24 13 01
1/25/2006 11:34:24 PM Waiting for IO info from Ocelot
And I get many xap messages with the following body
Event.Log
Time=1/25/2006 11:35:54 PM
Type=Warning
Data=Ocelot Plug-in, Checksum error reading io points: 2130 4864
Any ideas what I should check?
The problem is low level communications where the checksum in the RS232 message is not correct. It seems odd that it is only with IO and not variables unless you are not polling variables. If it is only with IO then I would look at this wiring interconnect.
I did not attempt to decode the bytestream you posted. This level of operation will more likely have better answers on the ADI message board. I could add some debug if you can provide some guidance as to what.
I did post my current version that I am running, but it will likely not make any difference to what you are seeing
I made a few changes and seemed to correct things, but was still getting checksum errors when telling xap Ocelot to go through IP directly. I downloaded a virtual driver for windows that communicates with IP, when using that driver and setting it up as COM5, then telling the xap Ocelot module to use COM5 I don't get any errors with checksum.
Not Working
I cannot get this program to detect my ocelot at all. It just times out. I know that the ocelot is working fine because it can be detected in both CMAX and the Homeseer plugin when I enable it. Is anyone using this program with a directly attached comm port?
Using xAP port 32771
Initializing X10 Interface on port 7
Version 2.0.42 Registered with Setup
Using Comm Port 7
Ocelot Plug-in Error, Timeout looking for CPU-XA/Ocelot
xapmcsADIOcelot looks for a period in the IP text box to determine if it should use IP or COM. If you leave the IP field blank then it should try to use the COM port number entered.
xapmcsADIOcelot.exe is an ActiveX and should be registered. I think registration of .exe's is done by launching the application with /regserver added on the command line.
I toggled between direct IP and COM8 via the Redirector driver and had success with both configurations. I'm running V2.0.44. My log is below that shows the startup feedback where it finds the ocelot and an SECU16. When I configure for COM8 I put the IP to blank the 8 for the port.
If you give me the exact message produced on your timeout then I can add some debug info that might help.
mcs.AdiOcelot.MCS6 2006-07-12 14:44:39 | xapmcsAdiOcelot | Using xAP port 32769
mcs.AdiOcelot.MCS6 2006-07-12 14:44:39 | xapmcsAdiOcelot | Version 2.0.44 Registered with Setup
mcs.AdiOcelot.MCS6 2006-07-12 14:44:39 | xapmcsAdiOcelot | Initializing X10 Interface on port 3002
mcs.AdiOcelot.MCS6 2006-07-12 14:44:41 | xapmcsAdiOcelot | Using Comm Port 192.168.0.40 3002
mcs.AdiOcelot.MCS6 2006-07-12 14:44:42 | xapmcsAdiOcelot | Found CPU-XA/Ocelot
mcs.AdiOcelot.MCS6 2006-07-12 14:44:42 | xapmcsAdiOcelot | Ocelot IR size: 1024
mcs.AdiOcelot.MCS6 2006-07-12 14:44:44 | xapmcsAdiOcelot | Unit found: SECU16 Addr: 1
mcs.AdiOcelot.MCS6 2006-07-12 14:46:30 | xapmcsAdiOcelot | Using xAP port 32769
mcs.AdiOcelot.MCS6 2006-07-12 14:46:30 | xapmcsAdiOcelot | Version 2.0.44 Registered with Setup
mcs.AdiOcelot.MCS6 2006-07-12 14:46:30 | xapmcsAdiOcelot | Initializing X10 Interface on port 8
mcs.AdiOcelot.MCS6 2006-07-12 14:46:33 | xapmcsAdiOcelot | Using Comm Port 8
mcs.AdiOcelot.MCS6 2006-07-12 14:46:33 | xapmcsAdiOcelot | Found CPU-XA/Ocelot
mcs.AdiOcelot.MCS6 2006-07-12 14:46:33 | xapmcsAdiOcelot | Ocelot IR size: 1024
mcs.AdiOcelot.MCS6 2006-07-12 14:46:35 | xapmcsAdiOcelot | Unit found: SECU16 Addr: 1
Thanks for looking into this problem.
This is the body of each xAP message I see after starting the Ocelot plugin:
time=7/13/2006 3:05:57 PM
type=xapmcsAdiOcelot
data=Using xAP port 32768
data=Version 2.0.42 Registered with Setup
data=Initializing X10 Interface on port 7
time=7/13/2006 3:05:59 PM
data=Using Comm Port 7
time=7/13/2006 3:06:03 PM
data=Ocelot Plug-in Error, Timeout looking for CPU-XA/Ocelot
time=7/13/2006 3:06:06 PM
