SimpleHomeNet EZRain & Insteon PLM 2413U Configuration Help
    <DIV id=post_message_928692>I have searched the forums for help on this topic but have not been successful to date. There are numerous posts but none that I have found with the level of detail that I require. I have a SimpleHomeNet EZRain irrigation controller and am hoping to leverage it via HS. I am looking for the following
    # 1) Someone that has the EZRain working with you Insteon Plugin (I am running the
    Not sure what happened to my initial post above by here is how it should read. Sorry about that.
    <DIV>I have searched the forums for help on this topic but have not been successful to date. There are numerous posts but none that I have found with the level of detail that I require. I have a SimpleHomeNet EZRain irrigation controller and am hoping to leverage it via HS. I am looking for the following
      Sorry guess I'll try this one more time:
      <DIV>- Someone that has the EZRain working with you Insteon Plugin (I am running the
        I think you need to delete these posts and start clean and don't use any html in the post
        Mark
        HS3 Pro 4.2.19.5
