My INSTEON plugin is continously crashing after HomeSeer is up for a couple of days. Not sure what is causing the issue as I am not on site only when called about an issue. Attached is the last quarter of the log file as it was too large to post the whole file.
INSTEON Plugin crashing
System.UnauthorizedAccessException: Access to the port is denied.
at System.IO.Ports.InternalResources.WinIOErrorS are you running? This line looks suspect:Last edited by Rupp; July 12, 2010, 12:54 PM.
Originally posted by Clever1 View PostMy INSTEON plugin is continously crashing after HomeSeer is up for a couple of days. Not sure what is causing the issue as I am not on site only when called about an issue. Attached is the last quarter of the log file as it was too large to post the whole file.
looks like the your usb PLM (i'm assuming) is dropping offline which is causing the plugin to throw errors.Mark
HS3 Pro 4.2.19.5
Guest
Save yourself some head ache and purchase the serial verion of the PLM
Just my 2 cents worth.
Mark's plug-in is very solid when combined with the serial PLM.
Rupp... Not sure what that means nor where to look for system info on it...
I appear to be running version 1.1.52.1 looking for an update now...
I did notice however that the Z-Wave USB controller and the PLM both seem to be using the same usb to serial driver as the interface to the devices. I wonder if this is causing some of the confusion.
The lastest version is in the sticky:
http://board.homeseer.com/showthread.php?t=141502
I accidentally typed What o in front of the error. I was simply pointing out that this was the suspect message.
Error when attempting to add devices manually
<TABLE cellSpacing=2 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=LOGEntry0 align=left colSpan=8>Calling PLM_AddID for 15.73.F5 1 True</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>7/20/2010 3:59:47 PM </TD><TD class=LOGType1 align=left colSpan=3>Insteon </TD><TD class=LOGEntry1 align=left colSpan=8>Error writing to the serialport, trying to reinitialize the PLM...</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>7/20/2010 3:59:47 PM </TD><TD class=LOGType0 align=left colSpan=3>Insteon </TD><TD class=LOGEntry0 align=left colSpan=8>Error writing to the serialport, trying to reinitialize the PLM...</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>7/20/2010 3:59:47 PM </TD><TD class=LOGType1 align=left colSpan=3>Insteon </TD><TD class=LOGEntry1 align=left colSpan=8>Error writing to the serialport, trying to reinitialize the PLM...</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>7/20/2010 3:59:47 PM </TD><TD class=LOGType0 align=left colSpan=3>Insteon </TD><TD class=LOGEntry0 align=left colSpan=8>** An error occurred in this plug-in. The details have been written to the log file - C:\Program Files\HomeSeer 2\Config\Insteon Error Report.Log</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>7/20/2010 3:59:47 PM </TD><TD class=LOGType1 align=left colSpan=3>Insteon </TD><TD class=LOGEntry1 align=left colSpan=8>** To request help with this problem please post this log file to the forum along with a detailed description of what lead to this problem.</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>7/20/2010 3:59:47 PM </TD><TD class=LOGType0 align=left colSpan=3>Insteon </TD><TD class=LOGEntry0 align=left colSpan=8>Calling PLM_AddID for 15.73.F5 1 False</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>7/20/2010 3:59:47 PM </TD><TD class=LOGType1 align=left colSpan=3>Insteon </TD><TD class=LOGEntry1 align=left colSpan=8>Com port closed! Attempting to reinitialized the Interface</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>7/20/2010 3:59:47 PM </TD><TD class=LOGType0 align=left colSpan=3>Insteon </TD><TD class=LOGEntry0 align=left colSpan=8>Could not open COM4 - System.UnauthorizedAccessException: Access to the port 'COM4' is denied. at System.IO.Ports.InternalResources.WinIOError(Int32 errorCode, String str) at System.IO.Ports.SerialStream..ctor(String portName, Int32 baudRate, Parity parity, Int32 dataBits, StopBits stopBits, Int32 readTimeout, Int32 writeTimeout, Handshake handshake, Boolean dtrEnable, Boolean rtsEnable, Boolean discardNull, Byte parityReplace) at System.IO.Ports.SerialPort.Open() at HSPI_INSTEON.HSPI.PLM_Interface_Initialize()</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>7/20/2010 3:59:48 PM </TD><TD class=LOGType1 align=left colSpan=3>Insteon </TD><TD class=LOGEntry1 align=left colSpan=8>Com port closed! Attempting to reinitialized the Interface</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>7/20/2010 3:59:48 PM </TD><TD class=LOGType0 align=left colSpan=3>Insteon </TD><TD class=LOGEntry0 align=left colSpan=8>Could not open COM4 - System.UnauthorizedAccessException: Access to the port 'COM4' is denied. at System.IO.Ports.InternalResources.WinIOError(Int32 errorCode, String str) at System.IO.Ports.SerialStream..ctor(String portName, Int32 baudRate, Parity parity, Int32 dataBits, StopBits stopBits, Int32 readTimeout, Int32 writeTimeout, Handshake handshake, Boolean dtrEnable, Boolean rtsEnable, Boolean discardNull, Byte parityReplace) at System.IO.Ports.SerialPort.Open() at HSPI_INSTEON.HSPI.PLM_Interface_Initialize()</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>7/20/2010 3:59:48 PM </TD><TD class=LOGType1 align=left colSpan=3>Insteon </TD><TD class=LOGEntry1 align=left colSpan=8>Calling PLM_RemoveID for 15.73.F5 1 True</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>7/20/2010 3:59:48 PM </TD><TD class=LOGType0 align=left colSpan=3>Insteon </TD><TD class=LOGEntry0 align=left colSpan=8>Com port closed! Attempting to reinitialized the Interface</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>7/20/2010 3:59:48 PM </TD><TD class=LOGType1 align=left colSpan=3>Insteon </TD><TD class=LOGEntry1 align=left colSpan=8>Could not open COM4 - System.UnauthorizedAccessException: Access to the port 'COM4' is denied. at System.IO.Ports.InternalResources.WinIOError(Int32 errorCode, String str) at System.IO.Ports.SerialStream..ctor(String portName, Int32 baudRate, Parity parity, Int32 dataBits, StopBits stopBits, Int32 readTimeout, Int32 writeTimeout, Handshake handshake, Boolean dtrEnable, Boolean rtsEnable, Boolean discardNull, Byte parityReplace) at System.IO.Ports.SerialPort.Open() at HSPI_INSTEON.HSPI.PLM_Interface_Initialize()</TD></TR></TBODY></TABLE>
Have you upgraded your ftdi chipset drivers to 2.6.2?Mark
HS3 Pro 4.2.19.5
Yes I have made sure that all drivers are up to date. I am just now getting back to working on the project after being off the tasks for several weeks. The plugin is still crashing, here is what is in the log:
<table width="100%" border="0" cellpadding="0" cellspacing="2"><tbody><tr><td colspan="1" class="LOGDateTime0" nowrap="nowrap" align="left">8/5/2010 11:19:28 AM </td><td colspan="3" class="LOGType0" align="left"> Insteon </td><td colspan="8" class="LOGEntry0" align="left">PLM_ProcessInBuffer received STX 0x52 (Raw X10 Rec):7E 00</td></tr> <tr> <td colspan="1" class="LOGDateTime1" nowrap="nowrap" align="left">8/5/2010 11:19:28 AM </td><td colspan="3" class="LOGType1" align="left"> Insteon </td><td colspan="8" class="LOGEntry1" align="left">PLM_ProcessInBuffer received STX 0x52 (Raw X10 Rec):72 80</td></tr> <tr> <td colspan="1" class="LOGDateTime0" nowrap="nowrap" align="left">8/5/2010 11:19:28 AM </td><td colspan="3" class="LOGType0" align="left"> X10 Received </td><td colspan="8" class="LOGEntry0" align="left">I2 (Utility Bathroom Floods) I On</td></tr> <tr> <td colspan="1" class="LOGDateTime1" nowrap="nowrap" align="left">8/5/2010 11:19:29 AM </td><td colspan="3" class="LOGType1" align="left"> Insteon </td><td colspan="8" class="LOGEntry1" align="left">PLM_ProcessInBuffer received STX 0x52 (Raw X10 Rec):7E 00</td></tr> <tr> <td colspan="1" class="LOGDateTime0" nowrap="nowrap" align="left">8/5/2010 11:19:29 AM </td><td colspan="3" class="LOGType0" align="left"> Insteon </td><td colspan="8" class="LOGEntry0" align="left">PLM_ProcessInBuffer received STX 0x52 (Raw X10 Rec):7E 00</td></tr> <tr> <td colspan="1" class="LOGDateTime1" nowrap="nowrap" align="left">8/5/2010 11:19:30 AM </td><td colspan="3" class="LOGType1" align="left"> Insteon </td><td colspan="8" class="LOGEntry1" align="left">PLM_ProcessInBuffer received STX 0x52 (Raw X10 Rec):73 80</td></tr> <tr> <td colspan="1" class="LOGDateTime0" nowrap="nowrap" align="left">8/5/2010 11:19:30 AM </td><td colspan="3" class="LOGType0" align="left"> X10 Received </td><td colspan="8" class="LOGEntry0" align="left">I2 (Utility Bathroom Floods) I2 (Utility Bathroom Floods) I Off</td></tr> <tr> <td colspan="1" class="LOGDateTime1" nowrap="nowrap" align="left">8/5/2010 11:19:31 AM </td><td colspan="3" class="LOGType1" align="left"> Insteon </td><td colspan="8" class="LOGEntry1" align="left">PLM_ProcessInBuffer received STX 0x52 (Raw X10 Rec):76 00</td></tr> <tr> <td colspan="1" class="LOGDateTime0" nowrap="nowrap" align="left">8/5/2010 11:19:31 AM </td><td colspan="3" class="LOGType0" align="left"> Insteon </td><td colspan="8" class="LOGEntry0" align="left">PLM_ProcessInBuffer received STX 0x52 (Raw X10 Rec):73 80</td></tr> <tr> <td colspan="1" class="LOGDateTime1" nowrap="nowrap" align="left">8/5/2010 11:19:31 AM </td><td colspan="3" class="LOGType1" align="left"> X10 Received </td><td colspan="8" class="LOGEntry1" align="left">I1 (Utility Bathroom Fan) I Off</td></tr> <tr> <td colspan="1" class="LOGDateTime0" nowrap="nowrap" align="left">8/5/2010 7:44:00 PM </td><td colspan="3" class="LOGType0" align="left"> Event </td><td colspan="8" class="LOGEntry0" align="left">Event Trigger "Sunset sequence"</td></tr> <tr> <td colspan="1" class="LOGDateTime1" nowrap="nowrap" align="left">8/5/2010 7:44:00 PM </td><td colspan="3" class="LOGType1" align="left"> Device Control </td><td colspan="8" class="LOGEntry1" align="left">Device: Utility Laundry - X10 I7 (_12) ON</td></tr> <tr> <td colspan="1" class="LOGDateTime0" nowrap="nowrap" align="left">8/5/2010 7:44:00 PM </td><td colspan="3" class="LOGType0" align="left"> Device Control </td><td colspan="8" class="LOGEntry0" align="left">Device: Outside Columns (D3) ON</td></tr> <tr> <td colspan="1" class="LOGDateTime1" nowrap="nowrap" align="left">8/5/2010 7:44:00 PM </td><td colspan="3" class="LOGType1" align="left"> Insteon </td><td colspan="8" class="LOGEntry1" align="left">Error writing to the serialport, trying to reinitialize the PLM...</td></tr> <tr> <td colspan="1" class="LOGDateTime0" nowrap="nowrap" align="left">8/5/2010 7:44:02 PM </td><td colspan="3" class="LOGType0" align="left"> Insteon </td><td colspan="8" class="LOGEntry0" align="left">Error writing to the serialport, trying to reinitialize the PLM...</td></tr> <tr> <td colspan="1" class="LOGDateTime1" nowrap="nowrap" align="left">8/5/2010 7:44:02 PM </td><td colspan="3" class="LOGType1" align="left"> Insteon </td><td colspan="8" class="LOGEntry1" align="left">Error writing to the serialport, trying to reinitialize the PLM...</td></tr> <tr> <td colspan="1" class="LOGDateTime0" nowrap="nowrap" align="left">8/5/2010 7:44:02 PM </td><td colspan="3" class="LOGType0" align="left"> Insteon </td><td colspan="8" class="LOGEntry0" align="left">** An error occurred in this plug-in. The details have been written to the log file - C:\Program Files\HomeSeer 2\Config\Insteon Error Report.Log</td></tr> <tr> <td colspan="1" class="LOGDateTime1" nowrap="nowrap" align="left">8/5/2010 7:44:02 PM </td><td colspan="3" class="LOGType1" align="left"> Insteon </td><td colspan="8" class="LOGEntry1" align="left">** To request help with this problem please post this log file to the forum along with a detailed description of what lead to this problem.</td></tr> <tr> <td colspan="1" class="LOGDateTime0" nowrap="nowrap" align="left">8/5/2010 7:44:06 PM </td><td colspan="3" class="LOGType0" align="left"> Insteon </td><td colspan="8" class="LOGEntry0" align="left">Com port closed! Attempting to reinitialized the Interface</td></tr> <tr> <td colspan="1" class="LOGDateTime1" nowrap="nowrap" align="left">8/5/2010 7:44:06 PM </td><td colspan="3" class="LOGType1" align="left"> Insteon </td><td colspan="8" class="LOGEntry1" align="left">Could not open COM4 - System.UnauthorizedAccessException: Access to the port 'COM4' is denied. at System.IO.Ports.InternalResources.WinIOError(Int32 errorCode, String str) at System.IO.Ports.SerialStream..ctor(String portName, Int32 baudRate, Parity parity, Int32 dataBits, StopBits stopBits, Int32 readTimeout, Int32 writeTimeout, Handshake handshake, Boolean dtrEnable, Boolean rtsEnable, Boolean discardNull, Byte parityReplace) at System.IO.Ports.SerialPort.Open() at HSPI_INSTEON.HSPI.PLM_Interface_Initialize()</td></tr> <tr> <td colspan="1" class="LOGDateTime0" nowrap="nowrap" align="left">8/5/2010 7:44:06 PM </td><td colspan="3" class="LOGType0" align="left"> Insteon </td><td colspan="8" class="LOGEntry0" align="left">Com port closed! Attempting to reinitialized the Interface</td></tr> <tr> <td colspan="1" class="LOGDateTime1" nowrap="nowrap" align="left">8/5/2010 7:44:06 PM </td><td colspan="3" class="LOGType1" align="left"> Insteon </td><td colspan="8" class="LOGEntry1" align="left">Could not open COM4 - System.UnauthorizedAccessException: Access to the port 'COM4' is denied. at System.IO.Ports.InternalResources.WinIOError(Int32 errorCode, String str) at System.IO.Ports.SerialStream..ctor(String portName, Int32 baudRate, Parity parity, Int32 dataBits, StopBits stopBits, Int32 readTimeout, Int32 writeTimeout, Handshake handshake, Boolean dtrEnable, Boolean rtsEnable, Boolean discardNull, Byte parityReplace) at System.IO.Ports.SerialPort.Open() at HSPI_INSTEON.HSPI.PLM_Interface_Initialize()</td></tr> <tr> <td colspan="1" class="LOGDateTime0" nowrap="nowrap" align="left">8/5/2010 7:44:06 PM </td><td colspan="3" class="LOGType0" align="left"> Insteon </td><td colspan="8" class="LOGEntry0" align="left">Com port closed! Attempting to reinitialized the Interface</td></tr> <tr> <td colspan="1" class="LOGDateTime1" nowrap="nowrap" align="left">8/5/2010 7:44:06 PM </td><td colspan="3" class="LOGType1" align="left"> Insteon </td><td colspan="8" class="LOGEntry1" align="left">Could not open COM4 - System.UnauthorizedAccessException: Access to the port 'COM4' is denied. at System.IO.Ports.InternalResources.WinIOError(Int32 errorCode, String str) at System.IO.Ports.SerialStream..ctor(String portName, Int32 baudRate, Parity parity, Int32 dataBits, StopBits stopBits, Int32 readTimeout, Int32 writeTimeout, Handshake handshake, Boolean dtrEnable, Boolean rtsEnable, Boolean discardNull, Byte parityReplace) at System.IO.Ports.SerialPort.Open() at HSPI_INSTEON.HSPI.PLM_Interface_Initialize()</td></tr> <tr> <td colspan="1" class="LOGDateTime0" nowrap="nowrap" align="left">8/5/2010 11:59:58 PM </td><td colspan="3" class="LOGType0" align="left"> System </td><td colspan="8" class="LOGEntry0" align="left">Switching to a new log file.</td></tr> <tr> <td colspan="1" class="LOGDateTime1" nowrap="nowrap" align="left">8/6/2010 6:03:00 AM </td><td colspan="3" class="LOGType1" align="left"> Event </td><td colspan="8" class="LOGEntry1" align="left">Event Trigger "Sunsrise Sequence"</td></tr> <tr> <td colspan="1" class="LOGDateTime0" nowrap="nowrap" align="left">8/6/2010 6:03:00 AM </td><td colspan="3" class="LOGType0" align="left"> Device Control </td><td colspan="8" class="LOGEntry0" align="left">Device: Outside Columns (D3) OFF</td></tr> <tr> <td colspan="1" class="LOGDateTime1" nowrap="nowrap" align="left">8/6/2010 6:03:00 AM </td><td colspan="3" class="LOGType1" align="left"> Device Control </td><td colspan="8" class="LOGEntry1" align="left">Device: Utility Laundry - X10 I7 (_12) OFF</td></tr> <tr> <td colspan="1" class="LOGDateTime0" nowrap="nowrap" align="left">8/6/2010 6:03:00 AM </td><td colspan="3" class="LOGType0" align="left"> Insteon </td><td colspan="8" class="LOGEntry0" align="left">Com port closed! Attempting to reinitialized the Interface</td></tr> <tr> <td colspan="1" class="LOGDateTime1" nowrap="nowrap" align="left">8/6/2010 6:03:00 AM </td><td colspan="3" class="LOGType1" align="left"> Insteon </td><td colspan="8" class="LOGEntry1" align="left">Could not open COM4 - System.UnauthorizedAccessException: Access to the port 'COM4' is denied. at System.IO.Ports.InternalResources.WinIOError(Int32 errorCode, String str) at System.IO.Ports.SerialStream..ctor(String portName, Int32 baudRate, Parity parity, Int32 dataBits, StopBits stopBits, Int32 readTimeout, Int32 writeTimeout, Handshake handshake, Boolean dtrEnable, Boolean rtsEnable, Boolean discardNull, Byte parityReplace) at System.IO.Ports.SerialPort.Open() at HSPI_INSTEON.HSPI.PLM_Interface_Initialize()</td></tr> <tr> <td colspan="1" class="LOGDateTime0" nowrap="nowrap" align="left">8/6/2010 6:03:00 AM </td><td colspan="3" class="LOGType0" align="left"> Insteon </td><td colspan="8" class="LOGEntry0" align="left">Com port closed! Attempting to reinitialized the Interface</td></tr> <tr> <td colspan="1" class="LOGDateTime1" nowrap="nowrap" align="left">8/6/2010 6:03:00 AM </td><td colspan="3" class="LOGType1" align="left"> Insteon </td><td colspan="8" class="LOGEntry1" align="left">Could not open COM4 - System.UnauthorizedAccessException: Access to the port 'COM4' is denied. at System.IO.Ports.InternalResources.WinIOError(Int32 errorCode, String str) at System.IO.Ports.SerialStream..ctor(String portName, Int32 baudRate, Parity parity, Int32 dataBits, StopBits stopBits, Int32 readTimeout, Int32 writeTimeout, Handshake handshake, Boolean dtrEnable, Boolean rtsEnable, Boolean discardNull, Byte parityReplace) at System.IO.Ports.SerialPort.Open() at HSPI_INSTEON.HSPI.PLM_Interface_Initialize()</td></tr> </tbody></table>
my only other suggestion is to try putting a usb hub between the plm and the usb port on the pc.
i have had no little luck recoverying from this problem. the problem is the usb connection between the usb plm and pc drops and puts the virtual com port into an unrecoverable state.
i can make this plugin shutdown more gracefully and have it send a trigger so you can create an event to notify yourself, but i can't do much more than that at this time.
i have this same problem with another plugin using a different usb deviceMark
HS3 Pro 4.2.19.5
So there is no fix for this?? That's not good I have this installed on a clients system and the house is rented out so we don't always have access to the system. The client is very very very demanding and will not be happy with this news...
Is there no fix out there???? I have to have a realible system!!!!
Originally posted by Clever1 View PostAre others having the same issues??
Could it be the computer itself??
there are definitely a handful of people having this same issue using the 2413u, but i don't think everyone with a 2413u is having this issue.
i guess its time for me to send a msgs to my smarthome contact and see what they have to say. i'll start a new thread when i hear back.Mark
HS3 Pro 4.2.19.5
As another user stated I also switched over to the serial controller and have had no issues to date.
I did have a few issues with the USB controller (similiar issues with the UPB USB controller).
You may want to adjust your registery entries to clean up both serial and USB ports. Many times the applications / plugins will leave "phantom" ports configured and untouchable.Attached Files- Pete
i also read something about not using com1-4 for virtual ports. change to com5 or higherMark
HS3 Pro 4.2.19.5
