Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > Insteon Plug-in (Mark Sandler)
Insteon Plug-in (Mark Sandler) Discussions related to Mark Sandler's 3rd parth plug-in for controlling Insteon devices via Smarthome's PLM interfaces (the 2412 & 2413 series controllers)
Old July 16th, 2010, 07:58 AM
skozin's Avatar
skozin skozin is offline
How to control keypadlinc buttons
Ok here is what I want to do:
I have a Keypadlinc with buttons A, B, C and D. A, B and C control a set of lights in my basement. They are linked to other Switchlincs. Button D is programmed when clicked on, to turn on A, B and C, which will turn on all the lights in my basement (A, B and C) and the corresponding switchlincs.
Now the dilemma, say I push A, B and C on, (D is still off) how do I tell Homeseer ok the 3 buttons are on then that means all the lights are on then Homeseer should put button D on?
Can someone show my what to do? I tried a conditional event but can't get it to work.
Steve
Old July 17th, 2010, 10:01 AM
CJVann's Avatar
CJVann CJVann is offline
Just create an event - if your 3 basement lights are on, and Button-D is off, turn button D ON (Remember KeypadLinc LED's only turn on when you turn on a Scene that includes the button.)
You might want another event such that if Button-D is on, but Not (Light 1 and Light 2 and Light 3), then turn Button-D OFF.
Old July 17th, 2010, 12:40 PM
skozin's Avatar
That is what I was looking for. I forgot to put Button D as part of the condition, so it wasn't working at first. This is how I set it up to make it work.
Event 1:
Turn Off Basement Button D If A B C Are Turned Off Condition
Device: BAS Insteon Basement Keypad Button A - Basement TV Lights is OFF
AND
Device: BAS Insteon Basement Keypad Button B - Basement Workout Lights is OFF
AND
Device: BAS Insteon Basement Keypad Button C - Basement East Lights is OFF
AND
Device: BAS Insteon Basement Keypad Button D - All Basement Lights is ON
WHEN
Everyday
Device Command: BAS Insteon Basement Keypad Button D - All Basement Lights Off
Event 2:
Turn On Basement Button D If Buttons A B C Are On Condition
Device: BAS Insteon Basement Keypad Button A - Basement TV Lights is ON
AND
Device: BAS Insteon Basement Keypad Button B - Basement Workout Lights is ON
AND
Device: BAS Insteon Basement Keypad Button C - Basement East Lights is ON
AND
Device: BAS Insteon Basement Keypad Button D - All Basement Lights is OFF
WHEN
Everyday
Device Command: BAS Insteon Basement Keypad Button D - All Basement Lights On
Thanks!!!!
Old July 17th, 2010, 03:14 PM
skozin's Avatar
Well it works temporarily. I get into a loop which then will turn on and off the lights. Here is the log:
7/17/2010 1:57:47 PM ~!~Insteon~!~Received \21 (Insteon Basement Keypad Button D - All Basement Lights) Go OFF
7/17/2010 1:57:47 PM ~!~Event~!~Event Trigger "Basement Keypad Button D Turned Off"
7/17/2010 1:57:47 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button D - All Basement Lights (\21+18+19+20) OFF
7/17/2010 1:57:47 PM ~!~Event~!~Event Trigger "Basement Keypad Button A Turned Off"
7/17/2010 1:57:47 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button A - Basement TV Lights (\18+15) OFF
7/17/2010 1:57:47 PM ~!~Event~!~Event Trigger "Basement Keypad Button B Turned Off"
7/17/2010 1:57:47 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button B - Basement Workout Lights (\19+16) OFF
7/17/2010 1:57:52 PM ~!~Insteon~!~Received \20 (Insteon Basement Keypad Button C - Basement East Lights) Go ON
7/17/2010 1:57:52 PM ~!~Event~!~Event Trigger "Basement Keypad Button C Turned On"
7/17/2010 1:57:52 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button C - Basement East Lights (\20+14) ON
7/17/2010 1:57:52 PM ~!~Event~!~Event Trigger "Basement East Lights Turned On By Remote"
7/17/2010 1:57:52 PM ~!~Device Control~!~Device: BAS Insteon Stairway East Lights (\45) ON
7/17/2010 1:57:56 PM ~!~Insteon~!~Received \21 (Insteon Basement Keypad Button D - All Basement Lights) Go ON
7/17/2010 1:57:56 PM ~!~Event~!~Event Trigger "Basement Keypad Button D Turned On"
7/17/2010 1:57:56 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button D - All Basement Lights (\21+18+19+20) ON
7/17/2010 1:57:56 PM ~!~Event~!~Event Trigger "Basement Keypad Button A Turned On"
7/17/2010 1:57:56 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button A - Basement TV Lights (\18+15) ON
7/17/2010 1:57:56 PM ~!~Event~!~Event Trigger "Basement Keypad Button B Turned On"
7/17/2010 1:57:56 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button B - Basement Workout Lights (\19+16) ON
7/17/2010 1:58:00 PM ~!~Insteon~!~Received \21 (Insteon Basement Keypad Button D - All Basement Lights) Go OFF
7/17/2010 1:58:00 PM ~!~Event~!~Event Trigger "Basement Keypad Button D Turned Off"
7/17/2010 1:58:00 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button D - All Basement Lights (\21+18+19+20) OFF
7/17/2010 1:58:00 PM ~!~Event~!~Event Trigger "Turn On Basement Button D If Buttons A B C Are On"
7/17/2010 1:58:00 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button D - All Basement Lights (\21) ON
7/17/2010 1:58:00 PM ~!~Event~!~Event Trigger "Basement Keypad Button A Turned Off"
7/17/2010 1:58:00 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button A - Basement TV Lights (\18+15) OFF
7/17/2010 1:58:00 PM ~!~Script~!~Script Insteon_ExtDevSupport.vb is currently running, waiting for it complete before its run again
7/17/2010 1:58:00 PM ~!~Event~!~Event Trigger "Basement Keypad Button C Turned Off"
7/17/2010 1:58:00 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button C - Basement East Lights (\20+14) OFF
7/17/2010 1:58:00 PM ~!~Event~!~Event Trigger "Basement Keypad Button B Turned Off"
7/17/2010 1:58:00 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button B - Basement Workout Lights (\19+16) OFF
7/17/2010 1:58:00 PM ~!~Event~!~Event Trigger "Basement Keypad Button D Turned On"
7/17/2010 1:58:00 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button D - All Basement Lights (\21+18+19+20) ON
7/17/2010 1:58:00 PM ~!~Event~!~Event Trigger "Turn Off Basement Button D If A B C Are Turned Off"
7/17/2010 1:58:00 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button D - All Basement Lights (\21) OFF
7/17/2010 1:58:00 PM ~!~Event~!~Event Trigger "Basement East Lights Turned Off By Remote"
7/17/2010 1:58:00 PM ~!~Device Control~!~Device: BAS Insteon Stairway East Lights (\45) OFF
7/17/2010 1:58:00 PM ~!~Event~!~Event Trigger "Basement Keypad Button A Turned On"
7/17/2010 1:58:00 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button A - Basement TV Lights (\18+15) ON
7/17/2010 1:58:00 PM ~!~Event~!~Event Trigger "Basement Keypad Button C Turned On"
7/17/2010 1:58:00 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button C - Basement East Lights (\20+14) ON
7/17/2010 1:58:00 PM ~!~Event~!~Event Trigger "Basement Keypad Button B Turned On"
7/17/2010 1:58:00 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button B - Basement Workout Lights (\19+16) ON
7/17/2010 1:58:00 PM ~!~Event~!~Event Trigger "Basement East Lights Turned On By Remote"
7/17/2010 1:58:00 PM ~!~Device Control~!~Device: BAS Insteon Stairway East Lights (\45) ON
7/17/2010 1:58:01 PM ~!~Event~!~Event Trigger "Basement Keypad Button A Turned Off"
7/17/2010 1:58:01 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button A - Basement TV Lights (\18+15) OFF
7/17/2010 1:58:01 PM ~!~Event~!~Event Trigger "Basement Keypad Button C Turned Off"
7/17/2010 1:58:01 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button C - Basement East Lights (\20+14) OFF
7/17/2010 1:58:01 PM ~!~Event~!~Event Trigger "Basement Keypad Button B Turned Off"
7/17/2010 1:58:01 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button B - Basement Workout Lights (\19+16) OFF
7/17/2010 1:58:01 PM ~!~Event~!~Event Trigger "Basement Keypad Button D Turned On"
7/17/2010 1:58:01 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button D - All Basement Lights (\21+18+19+20) ON
7/17/2010 1:58:01 PM ~!~Event~!~Event Trigger "Turn Off Basement Button D If A B C Are Turned Off"
7/17/2010 1:58:01 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button D - All Basement Lights (\21) OFF
7/17/2010 1:58:01 PM ~!~Event~!~Event Trigger "Basement East Lights Turned Off By Remote"
7/17/2010 1:58:01 PM ~!~Device Control~!~Device: BAS Insteon Stairway East Lights (\45) OFF
7/17/2010 1:58:01 PM ~!~Event~!~Event Trigger "Basement Keypad Button A Turned On"
7/17/2010 1:58:01 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button A - Basement TV Lights (\18+15) ON
7/17/2010 1:58:01 PM ~!~Event~!~Event Trigger "Basement Keypad Button C Turned On"
7/17/2010 1:58:01 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button C - Basement East Lights (\20+14) ON
7/17/2010 1:58:01 PM ~!~Event~!~Event Trigger "Basement Keypad Button B Turned On"
7/17/2010 1:58:01 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button B - Basement Workout Lights (\19+16) ON
7/17/2010 1:58:01 PM ~!~Event~!~Event Trigger "Basement Keypad Button D Turned Off"
7/17/2010 1:58:01 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button D - All Basement Lights (\21+18+19+20) OFF
7/17/2010 1:58:01 PM ~!~Event~!~Event Trigger "Turn On Basement Button D If Buttons A B C Are On"
7/17/2010 1:58:01 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button D - All Basement Lights (\21) ON
7/17/2010 1:58:01 PM ~!~Event~!~Event Trigger "Basement East Lights Turned On By Remote"
7/17/2010 1:58:01 PM ~!~Device Control~!~Device: BAS Insteon Stairway East Lights (\45) ON
7/17/2010 1:58:02 PM ~!~Event~!~Event Trigger "Basement East Lights Turned Off By Remote"
7/17/2010 1:58:02 PM ~!~Device Control~!~Device: BAS Insteon Stairway East Lights (\45) OFF
7/17/2010 1:58:02 PM ~!~Event~!~Event Trigger "Turn Off Basement Button D If A B C Are Turned Off"
7/17/2010 1:58:02 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button D - All Basement Lights (\21) OFF
7/17/2010 1:58:02 PM ~!~Event~!~Event Trigger "Basement Keypad Button A Turned On"
7/17/2010 1:58:02 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button A - Basement TV Lights (\18+15) ON
7/17/2010 1:58:02 PM ~!~Event~!~Event Trigger "Basement Keypad Button C Turned On"
7/17/2010 1:58:02 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button C - Basement East Lights (\20+14) ON
7/17/2010 1:58:02 PM ~!~Event~!~Event Trigger "Basement Keypad Button B Turned On"
7/17/2010 1:58:02 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button B - Basement Workout Lights (\19+16) ON
7/17/2010 1:58:02 PM ~!~Event~!~Event Trigger "Basement Keypad Button D Turned Off"
7/17/2010 1:58:02 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button D - All Basement Lights (\21+18+19+20) OFF
7/17/2010 1:58:02 PM ~!~Event~!~Event Trigger "Turn On Basement Button D If Buttons A B C Are On"
7/17/2010 1:58:02 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button D - All Basement Lights (\21) ON
7/17/2010 1:58:02 PM ~!~Event~!~Event Trigger "Basement East Lights Turned On By Remote"
7/17/2010 1:58:02 PM ~!~Device Control~!~Device: BAS Insteon Stairway East Lights (\45) ON
7/17/2010 1:58:02 PM ~!~Event~!~Event Trigger "Basement Keypad Button A Turned Off"
7/17/2010 1:58:02 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button A - Basement TV Lights (\18+15) OFF
7/17/2010 1:58:02 PM ~!~Event~!~Event Trigger "Basement Keypad Button C Turned Off"
7/17/2010 1:58:02 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button C - Basement East Lights (\20+14) OFF
7/17/2010 1:58:02 PM ~!~Event~!~Event Trigger "Basement Keypad Button B Turned Off"
7/17/2010 1:58:02 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button B - Basement Workout Lights (\19+16) OFF
7/17/2010 1:58:02 PM ~!~Event~!~Event Trigger "Basement Keypad Button D Turned On"
7/17/2010 1:58:02 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button D - All Basement Lights (\21+18+19+20) ON
7/17/2010 1:58:03 PM ~!~Event~!~Event Trigger "Turn On Basement Button D If Buttons A B C Are On"
7/17/2010 1:58:03 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button D - All Basement Lights (\21) ON
7/17/2010 1:58:03 PM ~!~Event~!~Event Trigger "Basement East Lights Turned On By Remote"
7/17/2010 1:58:03 PM ~!~Device Control~!~Device: BAS Insteon Stairway East Lights (\45) ON
7/17/2010 1:58:03 PM ~!~Event~!~Event Trigger "Basement Keypad Button A Turned Off"
7/17/2010 1:58:03 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button A - Basement TV Lights (\18+15) OFF
7/17/2010 1:58:03 PM ~!~Event~!~Event Trigger "Basement Keypad Button C Turned Off"
7/17/2010 1:58:03 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button C - Basement East Lights (\20+14) OFF
7/17/2010 1:58:03 PM ~!~Event~!~Event Trigger "Basement Keypad Button B Turned Off"
7/17/2010 1:58:03 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button B - Basement Workout Lights (\19+16) OFF
7/17/2010 1:58:03 PM ~!~Event~!~Event Trigger "Basement Keypad Button D Turned On"
7/17/2010 1:58:03 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button D - All Basement Lights (\21+18+19+20) ON
7/17/2010 1:58:03 PM ~!~Event~!~Event Trigger "Turn Off Basement Button D If A B C Are Turned Off"
7/17/2010 1:58:03 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button D - All Basement Lights (\21) OFF
7/17/2010 1:58:03 PM ~!~Event~!~Event Trigger "Basement East Lights Turned Off By Remote"
7/17/2010 1:58:03 PM ~!~Device Control~!~Device: BAS Insteon Stairway East Lights (\45) OFF
7/17/2010 1:58:03 PM ~!~Event~!~Event Trigger "Basement Keypad Button A Turned On"
7/17/2010 1:58:03 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button A - Basement TV Lights (\18+15) ON
7/17/2010 1:58:03 PM ~!~Event~!~Event Trigger "Basement Keypad Button C Turned On"
7/17/2010 1:58:03 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button C - Basement East Lights (\20+14) ON
7/17/2010 1:58:03 PM ~!~Event~!~Event Trigger "Basement Keypad Button B Turned On"
7/17/2010 1:58:03 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button B - Basement Workout Lights (\19+16) ON
7/17/2010 1:58:03 PM ~!~Event~!~Event Trigger "Basement Keypad Button D Turned Off"
7/17/2010 1:58:03 PM ~!~Device Control~!~Device: BAS Insteon Basement Keypad Button D - All Basement Lights (\21+18+19+20) OFF
That is just a few seconds. Any suggestions?
Steve
Old July 17th, 2010, 04:31 PM
skozin's Avatar
Wait, I think I figured it out. I had an event that ran when Button D turned on. I disabled that and (crossing my fingers), no loop.
Steve
HTML code is On
