Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > Insteon Plug-in (Mark Sandler)
Insteon Plug-in (Mark Sandler) Discussions related to Mark Sandler's 3rd parth plug-in for controlling Insteon devices via Smarthome's PLM interfaces (the 2412 & 2413 series controllers)
Old August 5th, 2010, 12:39 PM
kuntakintay's Avatar
kuntakintay kuntakintay is offline
bug - removing groups
When removing a group with existing links/device associations, the links are not removed from the device, causing lots of unreferenced links. If those links remain and you rebuild your system, the new configuration may reuse the link number and cause havoc.
Workaround is 1) go in and edit group, unchecking all associations before deleting. or 2) upon rebuilding to download all links, then go in to each device and delete all links manually, then reprogram/setup for homeseer and create new groups. However this is rather time consuming and a lot of work.
PS - Using 1.1.52.1 Insteon plugin...
HS 3.0.0.199 Pro/Insteon 3.0.5.20/3 Venstar Insteon Therms / Insteon Thermostat 3.0.2.2 / DirecTV 3.0.0.14 / OpenSprinkler 2.0.5.21 / ITunes DAAP 3.0.0.23/ UltraM1G3 3.0.5437.37424/ UltraWeatherbug3 /HSTouch Svr 3.0.0.68/Zwave 3.0.1.25/Ultramon3/Global Cache 5.0.0.17/Various BLXXX Plugins.
Old August 6th, 2010, 06:51 AM
mnsandler's Avatar
Insteon Overlord
have you tried v1.4.2 avail in the forum and updater
Mark
HS3 Pro 3.0.0.368
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon 3.0.6.23 (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire | RFXCOM | NetCAM | MyQ | BLRadar | Jon00 Charting
Old August 6th, 2010, 11:32 AM
1.4.2 is only for those using the PLM. I have a PLC.
Old August 6th, 2010, 05:00 PM
mnsandler's Avatar
Insteon Overlord
look for v1.3 then, this was the last version i built for the plc. Otherwise, time to upgrade to a plm
Old August 6th, 2010, 05:06 PM
Call me crazy, but the updater shows I am up-to-date. Did 1.3 ever get released to the HS updater?
Old August 6th, 2010, 08:09 PM
mnsandler's Avatar
Insteon Overlord
find v1.3 here
http://board.homeseer.com/showthread.php?t=139981
HTML code is On
