Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > Insteon Plug-in (Mark Sandler)
Insteon Plug-in (Mark Sandler) Discussions related to Mark Sandler's 3rd parth plug-in for controlling Insteon devices via Smarthome's PLM interfaces (the 2412 & 2413 series controllers)
Old August 10th, 2010, 10:52 PM
skozin's Avatar
skozin skozin is offline
A possible bug in plugin
Mark:
This bug I think was in the plugin before you started taking over. I have 2 switches and all the links are correct, but when I go into map device connections 2 of the links are incorrect.
Insteon Hallway Keypad (0C.89.C1):
->Button 2 controls Insteon Laundry Room Lights (05.4E.9D). Button 1 reflects back (2-way)
->Button 3 controls Insteon Kitchen Island Lights (12.8F.46). Button 1 reflects back (2-way)
->Button 3 controls Insteon Kitchen Table Keypad (0B.49.C1). Button 4 reflects back (2-way)
->Button 4 controls Insteon Kitchen Table Keypad (0B.49.C1). Button 4 reflects back (2-way) (Wrong should be button 1 reflects back)
->Button 5 controls Insteon Keypad Hallway-Great Room (0F.95.AA). Button 1 reflects back (2-way)
->Button 5 controls Insteon Foyer Keypad (12.3A.4B). Button 2 reflects back (2-way)
->Button 5 controls Insteon Hallway Downstairs (15.85.68). Button 1 reflects back (2-way)
->Button 5 controls Insteon Hallway-Kitchen Lights (15.81.26). Button 1 reflects back (2-way)
->Button 6 controls Insteon Living Room-Hallway Switch (15.81.8E). Button 1 reflects back (2-way)
->Button 6 controls Insteon Living Room-Den Switch (15.81.B8). Button 1 reflects back (2-way)
->Button 8 controls Insteon Great Room Hall Switch (12.D7.A5). Button 1 reflects back (2-way)
->Button 8 controls Insteon Great Room Kitchen Switch (04.47.92). Button 1 reflects back (2-way)
Insteon Kitchen Table Keypad (0B.49.C1):
->Button 1 controls Insteon Hallway Keypad (0C.89.C1). Button 4 reflects back (2-way)
->Button 4 controls Insteon Hallway Keypad (0C.89.C1). Button 4 reflects back (2-way) (Wrong- should be Button 3 reflects back)
->Button 4 controls Insteon Kitchen Island Lights (12.8F.46). Button 1 reflects back (2-way)
I have tried to delete the switches and relink, but the same think reoccurs.
Here are the device links:
HALLWAY KEYPAD:
Link #18 Button B controls Insteon Laundry Room Lights (05.4E.9D)
Link #27 Button C controls Insteon Kitchen Island Lights (12.8F.46)
Link #29 Button C controls Insteon Kitchen Table Keypad (0B.49.C1)
Link #10 Button D controls Insteon Kitchen Table Keypad (0B.49.C1)
Link #19 Button E controls Insteon Foyer Keypad (12.3A.4B)
Link #23 Button E controls Insteon Hallway Downstairs (15.85.68)
Link #25 Button E controls Insteon Hallway-Kitchen Lights (15.81.26)
Link #13 Button E controls Insteon Keypad Hallway-Great Room (0F.95.AA)
Link #16 Button F controls Insteon Living Room-Den Switch (15.81.B8)
Link #14 Button F controls Insteon Living Room-Hallway Switch (15.81.8E)
Link #39 Button H controls Insteon Great Room Hall Switch (12.D7.A5)
Link #41 Button H controls Insteon Great Room Kitchen Switch (04.47.92)
Link #1 Button A/Load has local control reporting to HomeSeer
Link #2 Button B has local control reporting to HomeSeer
Link #3 Button C has local control reporting to HomeSeer
Link #4 Button D has local control reporting to HomeSeer
Link #5 Button E has local control reporting to HomeSeer
Link #6 Button F has local control reporting to HomeSeer
Link #7 Button G has local control reporting to HomeSeer
Link #8 Button H has local control reporting to HomeSeer
Link #21 Button A/Load is controlled by HomeSeer using PLM Database Link #13 (Button Control Group) - On Level 100%, Ramp Rate .1 Sec.
Link #9 Button A/Load is controlled by HomeSeer using PLM Database Link #254 HomeSeer 'All Devices Group' - On Level 100%, Ramp Rate .1 Sec.
Link #22 Button B is controlled by HomeSeer using PLM Database Link #14 (Button Control Group) - Command: On
Link #17 Button B is controlled by Insteon Laundry Room Lights Switch/Load (05.4E.9D) using Insteon Link #1 - Command: On
Link #33 Button C is controlled by HomeSeer using PLM Database Link #15 (Button Control Group) - Command: On
Link #28 Button C is controlled by Insteon Kitchen Island Lights Switch/Load (12.8F.46) using Insteon Link #1 - Command: On
Link #30 Button C is controlled by Insteon Kitchen Table Keypad Button B (0B.49.C1) using Insteon Link #4 - Command: On
Link #34 Button D is controlled by HomeSeer using PLM Database Link #16 (Button Control Group) - Command: On
Link #11 Button D is controlled by Insteon Kitchen Table Keypad Button On/Load (0B.49.C1) using Insteon Link #1 - Command: On
Link #35 Button E is controlled by HomeSeer using PLM Database Link #17 (Button Control Group) - Command: On
Link #20 Button E is controlled by Insteon Foyer Keypad Button A/Load (12.3A.4B) using Insteon Link #1 - Command: On
Link #24 Button E is controlled by Insteon Hallway Downstairs Switch/Load (15.85.68) using Insteon Link #1 - Command: On
Link #26 Button E is controlled by Insteon Hallway-Kitchen Lights Switch/Load (15.81.26) using Insteon Link #1 - Command: On
Link #12 Button E is controlled by Insteon Keypad Hallway-Great Room Button On/Load (0F.95.AA) using Insteon Link #1 - Command: On
Link #36 Button F is controlled by HomeSeer using PLM Database Link #18 (Button Control Group) - Command: On
Link #31 Button F is controlled by Insteon Living Room-Den Switch Switch/Load (15.81.B8) using Insteon Link #1 - Command: On
Link #32 Button F is controlled by Insteon Living Room-Hallway Switch Switch/Load (15.81.8E) using Insteon Link #1 - Command: On
Link #37 Button G is controlled by HomeSeer using PLM Database Link #19 (Button Control Group) - Command: On
Link #15 Button H is controlled by HomeSeer using PLM Database Link #20 (Button Control Group) - Command: On
Link #38 Button H is controlled by Insteon Great Room Hall Switch Switch/Load (12.D7.A5) using Insteon Link #1 - Command: On
Link #40 Button H is controlled by Insteon Great Room Kitchen Switch Switch/Load (04.47.92) using Insteon Link #1 - Command: On
KITCHEN TABLE KEYPAD
Link #1 Button B controls Insteon Hallway Keypad (0C.89.C1)
Link #3 Button B controls Insteon Kitchen Island Lights (12.8F.46)
Link #5 Button On/Load controls Insteon Hallway Keypad (0C.89.C1)
Link #8 Button A has local control reporting to HomeSeer
Link #9 Button B has local control reporting to HomeSeer
Link #10 Button C has local control reporting to HomeSeer
Link #11 Button D has local control reporting to HomeSeer
Link #12 Button Off has local control reporting to HomeSeer
Link #7 Button On/Load has local control reporting to HomeSeer
Link #15 Button A is controlled by HomeSeer using PLM Database Link #22 (Button Control Group) - Command: On
Link #19 Button B is controlled by HomeSeer using PLM Database Link #23 (Button Control Group) - Command: On
Link #2 Button B is controlled by Insteon Hallway Keypad Button C (0C.89.C1) using Insteon Link #3 - Command: On
Link #4 Button B is controlled by Insteon Kitchen Island Lights Switch/Load (12.8F.46) using Insteon Link #1 - Command: On
Link #16 Button C is controlled by HomeSeer using PLM Database Link #24 (Button Control Group) - Command: On
Link #17 Button D is controlled by HomeSeer using PLM Database Link #25 (Button Control Group) - Command: On
Link #18 Button Off is controlled by HomeSeer using PLM Database Link #26 (Button Control Group) - Command: On
Link #14 Button On/Load is controlled by HomeSeer using PLM Database Link #21 (Button Control Group) - Command: On
Link #13 Button On/Load is controlled by HomeSeer using PLM Database Link #254 HomeSeer 'All Devices Group' - Command: On
Link #6 Button On/Load is controlled by Insteon Hallway Keypad Button D (0C.89.C1) using Insteon Link #4 - Command: On
Is there a way to fix this bug?
Steve
Old August 11th, 2010, 07:16 AM
mnsandler's Avatar
Insteon Overlord
can you also post just the device sections from the insteon.ini for the two devices. i would like to see the actual link data.
and can you tell me which link #s (from each device) you think are being references on the incorrect mappings?
Mark
HS3 Pro 3.0.0.368
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon 3.0.6.23 (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire | RFXCOM | NetCAM | MyQ | BLRadar | Jon00 Charting
Old August 11th, 2010, 07:27 AM
skozin's Avatar
[Device 8]
DeviceID=0C.89.C1
DeviceName=Hallway Keypad
DeviceLocation=Insteon
DeviceType=010C
FirmwareVer=2D
EEValues=DefaultRampRate=31,ResumeDim=138,FPTYPE=2,DefaultOn Level=255,OnLEDMask1=0,OnLEDMask2=0,OnLEDMask3=0,OnLEDMask4= 0,OnLEDMask5=0,OnLEDMask6=0,OnLEDMask7=0,OnLEDMask8=0,OffLED Mask1=0,OffLEDMask2=0,OffLEDMask3=0,OffLEDMask4=0,OffLEDMask 5=0,OffLEDMask6=0,OffLEDMask7=0,OffLEDMask8=0,NonToggleButto ns=0
DatabaseDelta=92
RecentDatabaseDelta=92
PollingInterval=0
LastContact=8/8/2010 9:17:59 PM
LinksDownloaded=1
NumLinks=41
Protocol=1
TotalInteractions=677
FailedInteractions=14
NoChannelSync=0
AutoShutoff=0
GroupLinkAddress 1=13
GroupLinkAddress 2=14
GroupLinkAddress 3=15
GroupLinkAddress 4=16
GroupLinkAddress 5=17
GroupLinkAddress 6=18
GroupLinkAddress 7=19
GroupLinkAddress 8=20
ChannelName1=Hallway Keypad Button A - Dining Room Lights
ChannelName2=Hallway Keypad Button B - Laundry Room Lights
ChannelName3=Hallway Keypad Button C - Kitchen Island Lights
ChannelName4=Hallway Keypad Button D- Kitchen Table Lights
ChannelName5=Hallway Keypad Button E - Hallway Lights
ChannelName6=Hallway Keypad Button F - Living Room Lights
ChannelName7=Hallway Keypad Button G - Den Lights
ChannelName8=Hallway Keypad Button H - Great Room Lights
Link 1=E2 01 0F D4 EF FF 1F 01 1
Link 2=E2 02 0F D4 EF FF 1F 02 2
Link 3=E2 03 0F D4 EF FF 1F 03 3
Link 4=E2 04 0F D4 EF FF 1F 04 4
Link 5=E2 05 0F D4 EF FF 1F 05 5
Link 6=E2 06 0F D4 EF FF 1F 06 6
Link 7=E2 07 0F D4 EF FF 1F 07 7
Link 8=E2 08 0F D4 EF FF 1F 08 8
Link 9=A2 FE 0F D4 EF FF 1F 01 9
Link 10=E2 04 0B 49 C1 FF 1F 01 12
Link 11=A2 01 0B 49 C1 FF 1F 04 13
Link 12=A2 01 0F 95 AA FF 1F 05 14
Link 13=E2 05 0F 95 AA FF 1F 01 15
Link 14=E2 06 15 81 8E 00 1F 06 16
Link 15=A2 14 0F D4 EF FF 1F 08 17
Link 16=E2 06 15 81 B8 00 1F 06 18
Link 17=A2 01 05 4E 9D FF 1F 02 22
Link 18=E2 02 05 4E 9D FF 1F 01 23
Link 19=E2 05 12 3A 4B FF 1F 01 26
Link 20=A2 01 12 3A 4B FF 1F 05 27
Link 21=A2 0D 0F D4 EF FF 1F 01 28
Link 22=A2 0E 0F D4 EF FF 1F 02 29
Link 23=E2 05 15 85 68 00 1F 05 34
SyncLinkedDevices=1
Link 24=A2 01 15 85 68 FF 1F 05 11
Link 25=E2 05 15 81 26 FF 1F 01 12
Link 26=A2 01 15 81 26 FF 1F 05 13
Link 27=E2 03 12 8F 46 FF 1F 01 10
Link 28=A2 01 12 8F 46 FF 1F 03 14
Link 29=E2 03 0B 49 C1 FF 1F 04 15
Link 30=A2 04 0B 49 C1 FF 1F 03 16
Link 31=A2 01 15 81 B8 FF 1F 06 25
Link 32=A2 01 15 81 8E FF 1F 06 27
Link 33=A2 0F 0F D4 EF FF 1F 03 28
Link 34=A2 10 0F D4 EF FF 1F 04 29
Link 35=A2 11 0F D4 EF FF 1F 05 30
Link 36=A2 12 0F D4 EF FF 1F 06 31
Link 37=A2 13 0F D4 EF FF 1F 07 33
Link 38=A2 01 12 D7 A5 FF 1F 08 36
Link 39=E2 08 12 D7 A5 FF 1F 01 37
Link 40=A2 01 04 47 92 FF 1F 08 42
Link 41=E2 08 04 47 92 FF 1F 01 43
[Device 9]
DeviceID=0B.49.C1
DeviceName=Kitchen Table Keypad
DeviceType=020F
FirmwareVer=32
EEValues=FPTYPE=0,OnLEDMask1=0,OnLEDMask2=0,OnLEDMask3=0,OnL EDMask4=0,OnLEDMask5=0,OnLEDMask6=0,OnLEDMask7=0,OnLEDMask8= 0,OffLEDMask1=0,OffLEDMask2=0,OffLEDMask3=0,OffLEDMask4=0,Of fLEDMask5=0,OffLEDMask6=0,OffLEDMask7=0,OffLEDMask8=0,NonTog gleButtons=0
DatabaseDelta=174
RecentDatabaseDelta=174
PollingInterval=0
LinksDownloaded=1
NumLinks=19
Protocol=1
TotalInteractions=323
FailedInteractions=4
NoChannelSync=0
AutoShutoff=0
GroupLinkAddress 1=21
GroupLinkAddress 2=22
GroupLinkAddress 3=23
GroupLinkAddress 4=24
GroupLinkAddress 5=25
GroupLinkAddress 6=26
ChannelName1=Kitchen Table Keypad Button On - Kitchen Table Lights
ChannelName2=Kitchen Table Keypad Button A
ChannelName3=Kitchen Table Keypad Button B - Kitchen Island Lights
ChannelName4=Kitchen Table Keypad Button C
ChannelName5=Kitchen Table Keypad Button D
ChannelName6=
SyncLinkedDevices=1
Link 1=E2 04 0C 89 C1 FF 1F 03 1
Link 2=A2 03 0C 89 C1 FF 1F 04 2
Link 3=E2 04 12 8F 46 FF 1F 01 3
Link 4=A2 01 12 8F 46 FF 1F 04 4
Link 5=E2 01 0C 89 C1 FF 1F 04 5
Link 6=A2 04 0C 89 C1 FF 1F 01 6
Link 7=E2 01 0F D4 EF FF 1F 01 7
Link 8=E2 03 0F D4 EF FF 1F 03 8
Link 9=E2 04 0F D4 EF FF 1F 04 9
Link 10=E2 05 0F D4 EF FF 1F 05 10
Link 11=E2 06 0F D4 EF FF 1F 06 11
Link 12=E2 08 0F D4 EF FF 1F 08 12
Link 13=A2 FE 0F D4 EF FF 1F 01 13
Link 14=A2 15 0F D4 EF FF 1F 01 14
Link 15=A2 16 0F D4 EF FF 1F 03 15
Link 16=A2 18 0F D4 EF FF 1F 05 17
Link 17=A2 19 0F D4 EF FF 1F 06 18
Link 18=A2 1A 0F D4 EF FF 1F 08 19
Link 19=A2 17 0F D4 EF FF 1F 04 16
From the Downstairs hallway Keypad It is Button C Link #30
From the Kitchen Keypad it is link #2
Last edited by mnsandler; August 11th, 2010 at 08:38 AM. Reason: just to highlight the links in question
Old August 12th, 2010, 11:27 AM
mnsandler's Avatar
Insteon Overlord
Steve,
give this a try. i did a little testing but my kpl links are a little messed up from all the different PLMs and testing i have been doing.
let me know
ps. i changed the routine that communicates with the plm so let me know if you see any problems sending cmds, etc
Old August 12th, 2010, 04:28 PM
skozin's Avatar
Looks good here are my connections:
->Button 4 controls Insteon Kitchen Table Keypad (0B.49.C1). Button 1 reflects back (2-way)
->Button 4 controls Insteon Hallway Keypad (0C.89.C1). Button 3 reflects back (2-way)
All I did was restart Homeseer. Did you want me to do anything else?
Steve
Old August 12th, 2010, 05:08 PM
mnsandler's Avatar
Insteon Overlord
glad its working.
so now that you are running a newer version with the latest plm routine, i just need you to keep an eye on your events, etc to make sure cmds are being sent out correctly/without issue.
if you have anything to report, please turn on detail debugging and post a log with your issue description.
this routine has been successfully tested by another user with a large installation so i don't anticipate any issues for you.
you might notice rereading links is quicker than before.
thanks
HTML code is On
