Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > Insteon Plug-in (Mark Sandler)
Insteon Plug-in (Mark Sandler) Discussions related to Mark Sandler's 3rd parth plug-in for controlling Insteon devices via Smarthome's PLM interfaces (the 2412 & 2413 series controllers)
Old August 25th, 2010, 08:22 PM
Rob2791's Avatar
Rob2791 Rob2791 is offline
Keypad LINC not logging a,b,c,d keys
Hey All,
I noticed Homeseer is not logging my KeypadLinc "a,b,c,d" keys
But i believe it is correctly executing a event if programed when i press a key.
I reset the KeypadLinc and reprogramed the links.
I have Homeseer PRO 2.4.0.11 and HSPI_Insteon.dll version 1.4.2.1.
Here is my Device Link Table:
Link #16 Button Off controls Kitchen SwitchLinc Dimmer 1 (12.6B.18)
Link #14 Button On/Load controls Kitchen SwitchLinc Dimmer 1 (12.6B.18)
Link #2 Button A has local control reporting to HomeSeer
Link #3 Button B has local control reporting to HomeSeer
Link #4 Button C has local control reporting to HomeSeer
Link #5 Button D has local control reporting to HomeSeer
Link #6 Button Off has local control reporting to HomeSeer
Link #1 Button On/Load has local control reporting to HomeSeer
Link #9 Button A is controlled by HomeSeer using Insteon Link #3 (Button Control Group) - Command: On
Link #10 Button B is controlled by HomeSeer using Insteon Link #4 (Button Control Group) - Command: On
Link #11 Button C is controlled by HomeSeer using Insteon Link #5 (Button Control Group) - Command: On
Link #12 Button D is controlled by HomeSeer using Insteon Link #6 (Button Control Group) - Command: On
Link #13 Button Off is controlled by HomeSeer using Insteon Link #7 (Button Control Group) - Command: On
Link #17 Button Off is controlled by Kitchen SwitchLinc Dimmer 1 Switch/Load (12.6B.18) using Insteon Link #1 - Command: Off
Link #8 Button On/Load is controlled by HomeSeer using Insteon Link #2 (Button Control Group) - On Level 100%, Ramp Rate .1 Sec.
Link #7 Button On/Load is controlled by HomeSeer using Insteon Link #254 HomeSeer 'All Devices Group' - On Level 100%, Ramp Rate .1 Sec.
Link #15 Button On/Load is controlled by Kitchen SwitchLinc Dimmer 1 Switch/Load (12.6B.18) using Insteon Link #1 - On Level 100%, Ramp Rate .1 Sec.
*Any reason they are not in number order?
Rob
Old August 26th, 2010, 11:10 AM
mnsandler's Avatar
Insteon Overlord
when you say "not logging my KeypadLinc "a,b,c,d" keys" are you referring to log entries in the hs log or updates to the status page?
the links are in a logical order based on their function so when people need help i can see things more easily.
Mark
HS3 Pro 3.0.0.368
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon 3.0.6.23 (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire | RFXCOM | NetCAM | MyQ | BLRadar | Jon00 Charting
Old August 26th, 2010, 01:19 PM
Rob2791's Avatar
When i press the a,b,c or d buttons it does not update the status or log an entry into hs log. But it works for the On/Load button and the Off button.
Old August 26th, 2010, 01:32 PM
mnsandler's Avatar
Insteon Overlord
that's strange since your links look correct.
turn on detailed debug logging and post a log snippet that captures a msg from the kpl when you manually press a btn (a,b,c, or d)
Old August 26th, 2010, 06:14 PM
Rob2791's Avatar
8/26/2010 6:13:34 PM Insteon PLM_ProcessInBuffer received STX 0x50 (Raw Insteon Rec):01 12 BB 92 13 27 1F 41 11 03 - Event: New msg for PLC , Src[12.BB.92] Dst[13.27.1F] {Grp Cln} Cmd:Go ON Ex: 03
That is what happens when i push the "a" button on.
Old August 26th, 2010, 06:22 PM
Rob2791's Avatar
I think this will also help..
This is the log of when i tried to poll all insteon devices. I only have 5 devices i believe right now so its not to long.
**Log Attached
Old August 26th, 2010, 08:32 PM
mnsandler's Avatar
Insteon Overlord
i need several more lines that occur after this msg.
please post your insteon.ini as well
Tags
insteon, keypadlinc
HTML code is On
