Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > UPB plugin by Spud (3P)
UPB plugin by Spud (3P) Spud UPB plugin discussions.
Old November 24th, 2017, 02:21 PM
beerguy beerguy is online now
Sporadic errors sending UPB commands
Hi Spud -
I've got your UPB plugin running on a Homeseer SEL and connected to a serial Simply Automated PIM through a USB-Serial interface. In general it has worked well for the last couple weeks testing. But twice now it has lost communication and I can't figure out what brings it back alive. Last time it happened I uninstalled the plug-in, swapped PIMs, restarted, etc. and something brought it back to life but I don't know which one.
I'm now getting this error again:
Nov-24 10:05:42 UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 7 [0714010BFF30AA] to PIM -- timed out 5 times -- discarding message
Edit: Here is some additional info in case it helps:
Comm port: /dev/ttyUSB0 (it hasn't changed since it was setup and worked)
UPBSpud version:
I also have UPBSpud working on a windows 7 pc with the same PIM at another house and it's been rock solid.
This one is in a remote location 200 miles away so I'd like to proceed carefully as to not lock up the machine.
Any ideas?
Old November 25th, 2017, 02:30 PM
I deleted the plugin from the HS PlugIns interface, restarted the SEL, reinstalled the plugin, and everything is working again.
Any ideas or thoughts on what I can do on this end so this doesn't happen?
Old November 25th, 2017, 03:17 PM
spud's Avatar
spud spud is offline
it's hard to say...
Did you try to just restart the SEL instead of deleting and reinstalling the plugin?
next time, set the log to debug, and try restarting the plugin or the SEL.
Commands not sending wcwolff UPB plugin by Spud (3P) 3 October 19th, 2015 07:32 AM
Errors on sending commands VirtualPanther DenonAVR (3P) 2 June 6th, 2013 03:44 PM
Sending TCP commands english_1969 HSTouch™ 2 April 6th, 2010 09:37 PM
Problems sending X-10 commands krm JDS (Stargate, TimeCommander) 9 August 19th, 2004 06:46 PM
Sending commands to the Temp05 knarfm Midon Design Temp05/08 5 January 30th, 2003 07:12 PM
