Thanks Jon00 you were right. I used IE and it worked. Dave...
Jon00 HTML to Image Utility
Sorry, I am trying to avoid asking this but have given up.
How do I insert the URL with the graphs into the HS screens? I know it is must be plastered everywhere.
What is a Text Element? It looks like some property in HS Touch ?
I've tried using HSDesigner in the past and got frustrated trying to resize existing screens to fit. People say there's a utility for it on here somewhere but have not stumbled across it yet. This is a different issue anyway.
Just want to inject the graphics into the HSTouch screen/stream/whatever.
I know this is a lame question. I'd love to make my own screens - just so many other cool things keep popping up to setup. Lack of patience, creativity, and graphic ability.
Here's a composite that I make up for upload to WUN using Jon's great scripts. I am starting to change this as I am going to a MP IP weather cam and going to make the picture a bit larger at 720P resolution such that there will be more "stuff" embedded in the upload.
I utilize the scripts for pages in HSTouch clients too. Works great.
The graph you see in this picture is generated by HS MCSTemperature and is an actual JPG. The radar picture from the internet.
The second picture attached is an HTML grab that I also utilize.
I save the HTML snapshots with Jon's script as a generic name for my weather stuff; IE: weathermap dot jpg dot com. This picture is updated every 10 minutes or so. If you put it in your HSTouch screen it'll update itself.
Go slow one thing at a time. Play around with the HSTouch screens; you can do much with them. Watch the you tube instructional videos available for HSTouch stuff. Experiement.
I connected a computer to the LCD display in the home office just to play with HSTouch screens and provide a base status on the house touch screens and to compensate for my "old" vision these days.. (3rd picture).- Pete
Hello Jon.
I've not tried this until today, but wanted to convert one of the HTML device strings that one of my scripts creates into an image so I could manipulate it a little easier in HSTouch. Unfortunately, your HTML2Image utility doesn't seem to like it. I get the following error in the HS log:
Error at Webgrab Subroutine Block 1 (Illegal characters in path.)
The device string displays just fine on the HS status page, and I've used it before in HSTouch where I had plenty of space.
I see others have had similar error in the Webgrab routine Block 1, but withdifferent causes (in the parens).
Any ideas? I can send you the html string in a file if you like.
Steve
Steve
Originally posted by jon00 View PostThe issue was actually caused by the use of the <hspath> tag in the image file path. This has now been corrected with V1.04 and available to download.
Thanks Jon!
Steve
Here starting to think about a remote indirect but direct status page of sorts say created with Jon's utility updated ever minute or so; but only providing status initially.- Pete
Originally posted by Pete View PostHere starting to think about a remote indirect but direct status page of sorts say created with Jon's utility updated ever minute or so; but only providing status initially.
Steve
Version 2 is now available
I have now updated this package to version 2 due to a known memory leak issue with the .NET WebBrowser object which is used by the script.
To update, you just need to replace the script and add the supplied exe file to your Homeseer root folder.
If you have any issues with this new version, please let me know.
Hm...Jon, link doesn't seem to be working.
I was able to download other things from your website, but not this (which I use a LOT to pull video from the web to push to my HStouch clients)...so I'd like to update ASAP.
--DanTasker, to a person who does Homeautomation...is like walking up to a Crack Treatment facility with a truck full of 3lb bags of crack. Then for each person that walks in and out smack them in the face with an open bag.
