I have the drivers installed running .21 version paid for of rxcom but can not get it to do anything even the Oregon Si sensor that was ordered with it will not show up in it at all. I have called Homeseer and they just refrer me to here. Ive not found anything to help with the problem. If you can help please let me know.
rfxcom will not find any of my OS or sonic view sensors
RFXCom not seeing devices
Harleyhawk22.
Did you try going to the device input screen of the plugin, once there you should be able to add your devices.
Not sure if you are using HS2 or HS3 but have a good read through the documentation, I think everything RFXCom you need to know is there.
If you still have trouble after this post again, Bart normally picks up on bugs very quickly.
Hope this is of help, I have been using RFXCom for ages it's pretty solid.
Peter
