Missing activities and International characters does not decode propertly
    Originally posted by janjoh View Post
    Can i trigger a sync via the plugin?
    (I am at work, i have removed the slash, but of course i need to trigger a sync of the hub)
    Just do a rescan of the activities on the hub devices page
    Rien du Pre
    The Netherlands
    Using:
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
      rien,
      same problem here,
      activities are not being populated anymore, for at least one of my hubs (the most important one). I also tried duplicating this hub as hub 5 and did a rescan.
      only activity that is detected is the poweroff
      Hub 5 Devices:
      - DVR Cams
      - XBMC Mediacenter
      - Tv Philips
      - AV-ontvanger Pioneer
      - Klimaatregeling Fujitsu
      - XBOX360
      - Sony BluRay Speler
      - Homeseer HS3
      - Horizon DVR
      Hub 5 Activities:
      - PowerOff
      but the activities that should populate are;
      Hub 1 Activities:
      - PowerOff
      - Radio
      - Internet Radio
      - Bluetooth
      - Front HDMI AV
      - DSaudio
      - XBMC Kijken
      - MiraCast
      - Smart-tv kijken
      - TV Kijken
      - MediaBluRay
      - Xbox 360 spelen
      - TV HDMI Side
      and the added activity which wont show up is "TV kijken via TV"
      I also added a nest as device, which is not detected, but i can imagine that this wont show because also hues are not listed.
      regards
      Bart
      Regards Bart
      Win7 64Bit on Intel NUCI7 with SSD
      HSPRO 3.
      Devices; 1370 Events; 691
      Jon00 Scripts, JowHue, HSTouch, Plugwise, Z-wave, Ultranetatmo, Ultracam, PHlocation, BLUSBUIRT, MeiHarmony, Buienradar, MEiUnifi Pushover 3P, Random, Nest HSPhone and Blueiris
      Visonic Powermax Alarm System (HS3) Interface: http://www.domoticaforum.eu/viewtopic.php?f=68&t=11129
        Same output. One activity.
          I'm also having problems with some of the activities and devices not showing up.
          I have 3 hubs. Not one of them have all activities shown and only one of them shows all the devices.
          One room is missing the device "Amazon Fire Tv" and the activity "Watch Fire Tv" but yet it shows "Watch Local Tv". I did try to remove spaces without luck and I see others show up with spaces and caps so I don't see a pattern why some show up and some don't.
          But not one of the 3 hubs show everything like it should. If you got any other tips or tricks as to why that would happen I'm open for ideas to try.
            Can you and Bart do the following.
            Go to the HomeSeer root folder on your system and execute the following command:
            bin\Harmonyhub\HArmonyHubControl list_activities
            And sent me the output
            This output is used in the plugin, if your activities are not listed the plugin won't show them too.
            Rien du Pre
            The Netherlands
            Using:
            Plugin's:
              #21
              Go to the root folder on your system and execute the following command:
              I'm on windows. Need a how to, or different instructions.
                #22
                hi i have the same problems only poweroff activities showing up
                  #23
                  See Bart's example screenshot in his post
                  Rien du Pre
                  The Netherlands
                  Using:
                  Plugin's:
                    #24
                    Wooow.
                    I did a firmware update on one of my hubs and now I have similar issues
                    Can all off you who are facing this issue with missing activities respond with your hub firmware version?
                    Rien du Pre
                    The Netherlands
                    Using:
                    Plugin's:
                      #25
                      Wooow.
                      I have bub firmware 4.12.36
                        #26
                        Rien,
                        I am also on 4.12.36...
                        Bart
                        Verzonden vanaf mijn iPhone met Tapatalk
                        Regards Bart
                        HSPRO 3.
                          #27
                          Yes and that's the version I upgraded to yesterday
                          Rien du Pre
                          The Netherlands
                          Using:
                          Plugin's:
                            #28
                            No update in the offical api documentation? Or are the activities not covered?
                            Regards Bart
                            HSPRO 3.
                              #29
                              I'm also on 4.12.36. I didn't run the output file, but i think you see the problem now.
                                #30
                                Me too.
