Randy;
I do not think the problems I am having in this post are directly related to this plug-in, but when the problem occurs, I get literally thousands of entries in the log about non reporting devices and reconnection attempts. Below is a snippet from the log showing OWServer reconnect attempts:
While I believe the plug-in hammering on reconnect attempts is the result of another failure, I can't help but wonder if the plug-in is a little relentless in trying to re-establish a connection. Do you think it might be an option to reduce the frequency of reconnect attempts, especially when all 3 servers lose their connections?
I may be barking up the wrong tree, but I am trying to resolve some really unusual behavior that began yesterday morning. Each of the 4 times HomeSeer has restarted is preceded by errors like above. When it restarted this morning at 5:46, these errors had been going on for about 6 hours, starting yesterday evening at about 11:30. There were well over 10,000 log entries just for OWServer reconnection attempts.
I also welcome suggestions as to how I might dig deeper to find out what is consuming so many TCPIP connections.
2017-07-13 23:30:57 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:57 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:57 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:53 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:53 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:53 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:49 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:49 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:49 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:45 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:45 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:45 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:41 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:41 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:41 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:37 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:37 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:37 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:33 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:33 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:33 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:29 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:29 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:29 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:25 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:25 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:25 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:21 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:21 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:21 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:16 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:16 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:16 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:12 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:12 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:12 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:08 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:08 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:08 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:04 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:04 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:04 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:00 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:00 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:30:00 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:56 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:56 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:56 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:52 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:52 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:52 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:48 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:48 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:48 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:44 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:44 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:44 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:40 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:40 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:40 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:36 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:36 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:36 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:31 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:31 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:31 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:27 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:27 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:27 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:23 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:23 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:23 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:19 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:19 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:19 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:15 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:15 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:15 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:11 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:11 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:11 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:07 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:07 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:07 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:03 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:03 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:29:03 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:28:59 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:28:59 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:28:59 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:28:55 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:28:55 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:28:55 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:28:51 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:28:51 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:28:51 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:28:47 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:28:47 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:28:47 Error The OWServer connection failed due to an error: Unable to connect to the remote server 2017-07-13 23:28:42 Error The OWServer connection failed due to an error: Unable to connect to the remote server
