Schedules Do Not Work Across Midnight -- Not documented in User Guide, so here it is
    I created 4 schedules just fine and then I wasted a30 min and a lot of trial and error to figure out that either there is a bug or this schedule has the same limitations that HS3 does with time management across midnight (e.g. no smarter than a 1st grader)
    I did not see this documented in the User Guide. So hope this saves someone time and maybe Spud can put this in the user guide.
    Ultimately I was hoping this plugin would work properly across midnight.
    these stick....
    [Mon 23:30;Mon 23:59],[Tue 23:30;Tue 23:59],[Wed 23:30;Wed 23:59],[Thu 23:30;Thu 23:59],[Fri 23:30;Fri 23:59],[Sat 23:30;Sat 23:59],[Sun 23:30;Sun 23:59]
    [Mon 00:00;Mon 06:00],[Tue 00:00;Tue 06:00],[Wed 00:00;Wed 06:00],[Thu 00:00;Thu 06:00],[Fri 00:00;Fri 06:00],[Sat 00:00;Sat 06:00],[Sun 00:00;Sun 06:00]
    these do not...
    [Mon 23:30;Mon 24:00],[Tue 23:30;Tue 24:00],[Wed 23:30;Wed 24:00],[Thu 23:30;Thu 24:00],[Fri 23:30;Fri 24:00],[Sat 23:30;Sat 24:00],[Sun 23:30;Sun 24:00]
    == BLANK
    Log:
    ERROR System.OverflowException: The TimeSpan could not be parsed because at least one of the numeric components is out of range or contains too many digits. at System.Globalization.TimeSpanParse.ProcessTerminal_HM(TimeSp anRawInfo& raw, TimeSpanStandardStyles style, TimeSpanResult& result) at System.Globalization.TimeSpanParse.ProcessTerminalState(Time SpanRawInfo& raw, TimeSpanStandardStyles style, TimeSpanResult& result) at System.Globalization.TimeSpanParse.TryParseTimeSpan(String input, TimeSpanStandardStyles style, IFormatProvider formatProvider, TimeSpanResult& result) at System.Globalization.TimeSpanParse.Parse(String input, IFormatProvider formatProvider) at HSPI_EasyTrigger.HSTimeSpan.Parse(String s) at HSPI_EasyTrigger.WeekScheduleTime.Parse(String s) at HSPI_EasyTrigger.WeekScheduleTimeSlot.Parse(String s) at HSPI_EasyTrigger.WeekSchedule.SetTimeSlots(String timeSlots)
    [Mon 23:30;Mon 00:00],[Tue 23:30;Tue 00:00],[Wed 23:30;Wed 00:00],[Thu 23:30;Thu 00:00],[Fri 23:30;Fri 00:00],[Sat 23:30;Sat 00:00],[Sun 23:30;Sun 00:00]
    == [Mon 23:30;Mon 00:00]
    Log:
    ERROR System.FormatException: end time Tue 00:00 cannot be before start time Tue 23:30 at HSPI_EasyTrigger.WeekScheduleTimeSlot.Parse(String s) at HSPI_EasyTrigger.WeekSchedule.SetTimeSlots(String timeSlots)
    [Mon 23:30;Mon 06:00],[Tue 23:30;Tue 06:00],[Wed 23:30;Wed 06:00],[Thu 23:30;Thu 06:00],[Fri 23:30;Fri 06:00],[Sat 23:30;Sat 06:00],[Sun 23:30;Sun 06:00]
    == BLANK
    Log:
    ERROR System.FormatException: end time Mon 06:00 cannot be before start time Mon 23:30 at HSPI_EasyTrigger.WeekScheduleTimeSlot.Parse(String s) at HSPI_EasyTrigger.WeekSchedule.SetTimeSlots(String timeSlots)
    Monday 00:00 is 12:00 AM on Monday making your schedule beginning time before the ending time. If you want [Mon 23:30;Mon 00:00] it is expressed as [Mon 23:30;Tue 00:00]. A schedule that ends at Midnight is expressed as 00:00 the next day. A schedule that ends at 00:00 ends at midnight the day before. A schedule that begins at 00:00 begins at 12:00:00 AM That day.
    There is no Mon 24:00 - Monday 24:00 is expressed as Tue 00:00.
    In all of these:
    Your start time is after your end time. Monday 23:30 (11:30 PM) is after Monday at 06:00 (6:00 AM).
    Perhaps you want:
    [Mon 23:30;Tue 06:00],[Tue 23:30;Wed 06:00],[Wed 23:30;Thu 06:00],[Thu 23:30;Fri 06:00],[Fri 23:30;Sat 06:00],[Sat 23:30;Sun 06:00],[Sun 23:30;Mon 00:00], [Mon 00:00;Monday 06:00]
    Note the break at Midnight on Sunday, which is a limitation of .NET and has been discussed here. A schedule cannot cross Midnight on Sunday Night/Monday Morning. You have to dig a little deeper for this one.
      Thank you. Makes perfect sense I was not thinking about it proper. This would be good to put in the Easy Trigger User Manual
      In all of these:
      Perhaps you want:
        Other than the .NET limitation for Sunday Night, the rest is pure 24 hour clock or military time. The day begins at 00:00 and ends at 00:00 (just after 23:59:59) there is no 24:00
          Next time, before claiming something does not work, please make sure you are not the one doing something no smarter than a 1st grader
          An easy way to see how date/time should be formatted for the schedules, is to use the graphical editor. Click and drag to create a time range, then drag and drop it to move it, this way you would have seen that it works across midnight.
            Tru... I did use the graphic editor on the first one but while it is cool, it was a bit difficult to align and takes longer than editing text and copying it in. But yes, it is nice!
            Sent from my SAMSUNG-SM-G935A using Tapatalk
