Easy Trigger Group
    #31
    Originally posted by andyf View Post
    I thought about that. When I was using location2 as the search criteria I abbreviated location2 for the devices I needed in the group. So Downstairs became KI. Downstairs became LR... etc. Now you were updating the plug-in to use the Config to create group name I reverted the location2 back to what it was. This caused the windows to be too small to identify the individual nodes. Is it possible to make the windows stretchable?
    I can't change the window size from the plugin, but we can do it by changing the css:
    edit html/css/hs.css and change the following lines (line 374):
    /* selector pop-up layout */
    .selectorleft {width:200px;}
    .selectorright {width:200px;}
    to
    .selectorleft {min-width:200px;}
    .selectorright {min-width:200px;}
    I will ask Rich, if this can be changed permanently in the next version of HS3
      #32
      Put the change in the custom.css file. It does not get overwritten when a new version is installed.
      The custom.css is intended to be used to override the hs.css.
      Jeff Farmer
      HS 3, HSPhone
        #33
        I made the changes to both files. Restarted HS. The window is the same size and doesn't seem to be stretchable. However, I can move the window around now. Not sure if it was that way before. Will revert back.
          #34
          I abbreviated location2 which allowed me to setup a group. The group contains all devices in the Kitchen that can be turned on or off. This is to allow me to light up an LED on a KeypadLinc to show that something in the Kitchen is ON.
          I turned on the debug log for EasyTrigger and get this when something in the Kitchen is turned ON.
          Oct-05 5:40:18 AM EasyTrigger DEBUG Device 403 changed
          Oct-05 5:40:17 AM EasyTrigger DEBUG Stack: at HSPI_EasyTrigger.EasyTriggerApp.HSEvent (HSEvent eventType, System.Object[] parms) [0x00000] in :0
          Oct-05 5:40:17 AM EasyTrigger ERROR HSEvent callback. Object reference not set to an instance of an object
          Oct-05 5:40:17 AM EasyTrigger DEBUG Device 22 value changed from 0 to 255
          Oct-05 5:40:17 AM Z-Wave Device: Downstairs Kitchen KI.(Cabinet-L)_ZW Set to 255
          Oct-05 5:40:17 AM EasyTrigger DEBUG Device 23 value changed from 0 to 255
          Oct-05 5:40:17 AM Z-Wave Device: Downstairs Kitchen KI.(Cabinet-R)_ZW Set to 255
          Oct-05 5:40:16 AM EasyTrigger DEBUG Stack: at HSPI_EasyTrigger.EasyTriggerApp.HSEvent (HSEvent eventType, System.Object[] parms) [0x00000] in :0
          Oct-05 5:40:16 AM EasyTrigger ERROR HSEvent callback. Object reference not set to an instance of an object
          Oct-05 5:40:16 AM EasyTrigger DEBUG Device 486 value changed from 0 to 100
          Oct-05 5:40:16 AM Device Control Device: Downstairs Kitchen KI.(Cabinet-L)_ZW to On (255)
          Oct-05 5:40:16 AM Event Event Trigger "KITCHEN KI.(KPL-B).CabinetLights.On"
            #35
            your web browser cache this css, you need to force a full refresh (shift + F5) after you made the changes
              #36
              You probably still have some old triggers built with the previous version, delete or update them and then restart the plugin.
                #37
                Excellent. That fixed the errors in the log. Didn't need to restart the plug-in. I guess it wasn't enough to disable the events. I'm going to try the window re-sizing now. Safari on a Mac is tough to clear it's caches even when you tell it to.
                  #38
                  The Custom.css has a comment that says it overrides Style.css. No mention of hs.css.
                    #39
                    to
                    Perfect. This resolves the window sizing issue. Thanks.
                      #40
                      to
                      Looking at Jeff's suggestion, I found some interesting behavior. Using min-width in hs.css works fine, but does get overwritten on a restart. The two windows dynamically resize to fit the devices. Adding min-width to custom.css has no effect, but setting the pixel width to 300 does. As a result I added
                      .selectorleft {width:300px;}
                      .selectorright {width:300px;}
                      This gives 50% more width to each window and does persist over a restart, but it is not dynamic like the code you suggest. I'm not sure if you want to point this out to Rich, but I did confirm it by going through the exercise a couple of times.
                        #41
                        I haven't tested, but I think you may need to override the width parameter in custom.css, so try this:
                        .selectorleft {min-width:200px; width:auto;}
                        .selectorright {min-width:200px; width:auto;}
                          #42
                          This does work.
                          Thanks.
                            #43
                            FYI, Rich just put the changes in the master css file.
                              #44
                              Works for me too.
                                #45
                                Spud
                                What happened to ALL in the Group? When I installed this beta looks like the only thing available is ANY.
