Hi Bert,
Feature request: DS10/90/SD90/MCT302 Security Sensor - Selectable status output device option.
I would like to have a selectable option to swap the status display output ( Normal / Alert ) on any of the security sensor devices in the RFXCOM plug-in.
This is so that when using a DS10 for other than a security device where it is used in N/C mode. When using the none security N/O mode, for example when used as a water detector. I would like to see a 'Normal' status displayed instead of the 'Alert 'status.
I still do a double take every time I see the yellow triangle icon on my water detector and door bell devices, and I have to check I am not missing a device that should be showing a 'Normal' status.
Thanks.
Cheers,
Frank.
Thanks.
Cheers,
Frank.
