Michael,
Everything has been OK for months
Since 2 weeks, my rain gauge is going crazy
On August 29th, I made a rough measurement with a graduated glass and found 35mm rain
During the same period (24 hours), HomeSeer indicates 3700mm rain !!!
This is an excerpt of the log file:
(normal interval 30 seconds as been raised to 300s for this test)
29/08/2007 21:28:42 ~!~mcsTemperature Debug~!~DS9x9x Port USB2 Device = DS2450 ED00000000D5DD20
29/08/2007 21:28:42 ~!~mcsTemperature Debug~!~Calibrate 68 with bias 0
29/08/2007 21:28:42 ~!~mcsTemperature Debug~!~DS9x9x Port USB2 Device = DS1920 7A0008001417B510
29/08/2007 21:28:43 ~!~mcsTemperature Debug~!~Calibrate 14.5625 with bias 0
29/08/2007 21:28:43 ~!~mcsTemperature Debug~!~DS9x9x Port USB2 Device = DS1920 B4000800BB727D10
29/08/2007 21:28:44 ~!~mcsTemperature Debug~!~Calibrate 16.625 with bias -0.3
29/08/2007 21:28:44 ~!~mcsTemperature Debug~!~DS9x9x Port USB2 Device = DS2438 430000009E71D626
29/08/2007 21:28:45 ~!~mcsTemperature Debug~!~DS9x9x Port USB2 Device = DS1990A CB0000002645BF81
29/08/2007 21:28:45 ~!~mcsTemperature Debug~!~DS9x9x Port USB2 Device = DS2423 D1000000019FF11D
29/08/2007 21:28:45 ~!~mcsTemperature Debug~!~Wind Speed Counter=755552, Prior Counter=753318, Interval=304 seconds
29/08/2007 21:28:45 ~!~mcsTemperature Debug~!~DS9x9x Port USB2 Device = DS2423 2100000007E3471D
29/08/2007 21:28:45 ~!~mcsTemperature Debug~!~ComputeWater Count=15075, Type=29, Device1=R5, Device2=R9, Interval = 300
29/08/2007 21:28:45 ~!~mcsTemperature Debug~!~Water Counter=15075, Prior Counter=15062, Interval=304 seconds
29/08/2007 21:28:45 ~!~mcsTemperature Debug~!~R5 Water Delta Seconds=304, Prior Value=15062, Current Value=15075, Rate=70.10905
29/08/2007 21:28:45 ~!~mcsTemperature Debug~!~ComputeWater Count=18589, Type=4, Device1=R10, Device2=R11, Interval = 300
29/08/2007 21:28:45 ~!~mcsTemperature Debug~!~Water Counter=18589, Prior Counter=18576, Interval=304 seconds
29/08/2007 21:28:45 ~!~mcsTemperature Debug~!~R10 Water Delta Seconds=304, Prior Value=18576, Current Value=18589, Rate=1018.574
Please let me know if having two water counters (R5, R10) is a normal situation
Should I delete devices and reinstall
Any other clues?
Possible hardware failure?
I enclose a longer portion of the log file
Thanks for your help
yves
Any other clues?
yves
