shifting images in IE
    Testing the plugin
    was running IE 11, but I could not move the icons.
    switched to compatibility view and that problem is solved.
    But when I save the floorplan, all icons shift way down.
    any suggestions?
    Have you tried Chrome?
    Cheers,
    Bob
      yes, I did.
      it does not allow me to do anything in chrome.
      I noticed that when I save the icons move a bit when I then go to view.
      when I go back to setup, the icons move a lot each time I save.
      but, this might not be the plugin I need anyways.
      I was hoping to be able to use the floor plan in HSTouch designer.
        I just tested it here with IE and it is working for me
        Can you attach a screenshot of your options page from the plugin
        Cheers,
        Bob
          attached
            Try this:
            Turn off "Adjust Page Spacing For Touchscreen Displays"
            Turn off "Center Floorplan on View Floorplan Web Page"
            Cheers,
            Bob
              no good, now even just view will move the icons further out of position.
              anyways, the plug in is not what I need for hstouch designer.
